Question about Nuova Simonelli Mac 2000 I Group Espresso & Coffee Maker
Boiler pressure low
I just purchased a used Nuova Simonelli Mac 200v single group espresso machine for my cafe. I love it, but I feel like the boiler pressure is low, preventing me from pulling a really good shot. It won't go up past 4 bars and I feel like it should really be at around 7-9 bars. Does anyone know how to adjust this. My steam pressure is ideal, right at 1.2 bars. There are no leaks in the machine either.
  • cookie973 Dec 20, 2008
    The steaming elements work great. I have no problem with steam. I cleaned the group and lines and still no pressure gain. It looks like the pump motor switch is trying to kick on the pump, but I get no action. The manometer's bottom gauge pulls back to around 1 bar for about 2-3 seconds then jumps back to 4 bars, but no motor is heard and pressure does not increase,
    I'm sorry, but you must be mistaking me for someone who knows what that means? I am new to the technical side of all this, so I need you to "hold my hand" through all this and try to explain it to me like I'm a six year old. Thanks and sorry.
  • 2,039 Answers
You said you clean the machine with vinergar or descaller use descaller vinegar not strong enought descaller melt the calcium vinergar remove it in chunks and can still be block after the cleaning and dont forget maybe the person who had that before you never did maintenanse on it descal it a few time let me noww pierre and how do you descalled it thanks
Posted on Dec 20, 2008
  • Nuova Simonelli Master
  • 19,396 Answers
Do a full cleaning cycle, if there is scale on the element water wont reach temperature and you get less pressure.
  • Ginko
    Ginko Dec 20, 2008
    If steam does not come out of the nozzle , and pressure is poor, it is usually a broblem with clogged lines or heating element.
    If the element is covered in scale it won't heath sufficiently.
    Check also that the nozzle sprayer is not clooged.
    If the lines are free, then either the heating element, or the pressure switch are defective.
  • Ginko
    Ginko Dec 20, 2008
    If the pump does not kick in at all, the pump mest be tested by energizing it.
Aurelia 4 group mystery leak below drip pan when unit is off
My 2 group Aurelia does this also and I have traced it back to a fitting on the boiler. It only leaks when off with no pressure...on mine it was the right tube/fitting on the boiler.
Mar 04, 2014 | Nuova Simonelli Aurelia Semi-automatic 4...
Nuova simonelli manual switch flashes
it means that no water is flowing on the flowmeters. need to check flowmeters if clogged
Jun 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
Nuova simonelli vip over pressure problem
Could be lack of water in the boiler, could be a faulty pressure stat or vent valve. Check the level probe first, then the vent valve and then the pressure stat. You can also use the manual fill to make sure water is getting to the boiler.
Jun 27, 2010 | Nuova Simonelli Microbar Espresso Machine
Burnt smell is coming from steamer wand
Boiler is contaminated with milk, check the water from the tea valve, if it smells the same or has swimmers, boiler needs to be descaled, if no floaties then removes steam wand and soak in purocaff for a few hours, then clean. Always flush ssteam wand before and after every drink.
Mar 04, 2010 | Nuova Simonelli Mac 2000 I Group Espresso...
Mac cup V commercial Nuova Simonelli will not **** water and will not build pressure
First check the reset thermostat on the right side of the boiler below the level probe, make sure there is water in the boiler before resetting.
Sep 25, 2009 | Nuova Simonelli Oscar Coffee Maker,...
Nuova simonelli appia 1 ....pump will not stop pumping so tank fu
Sounds like your auto level probe that goes into side of boiler is not in right position or not working .
Jan 02, 2009 | Nuova Simonelli Mac 2000 I Group Espresso...
Nuova simonelli mac cup red light
It sounds like the thermostat on the boiler nest to the element tripped. Fill machine with water until you can see the level about half way, then open the right side of the espresso machine, you might be able to get to thermostat from the top of machine (make sure it is unplugged) then press the red pin on the boiler between the 2 wires, that should reset the thermostat, if it does not then it will need to be replaced. As for the water on the top of the group head, is there any way you can post a pic of the top, because simonelli made a few different head and I want to give you the correct advise.
Nov 13, 2008 | Nuova Simonelli Premier Maxi Espresso...
Boiler does not refill properly
Chances are, your level probe (rhs of the boiler) is dirty/scaled.Then the probe is always earthed and does not allow water in as it thinks it's always full.
Take it out and clean with wire wool(obv with no pressure in the boiler).It should have a red wire attached to it.
When you refit it, make sure the part inside the boiler faces down.
Feb 04, 2008 | Nuova Simonelli Mac 2000 I Group Espresso...
OSCAR NUOVA SIMONELLI WONT" GO ABOVE 165F AT GROUPHEAD
Descale boiler and group then make sure steam gauge reads 1.2 bar. If not adjust p.stat.
Jun 08, 2007 | Nuova Simonelli Oscar Coffee Maker,...
Nuova Simonelli Mac 2000 I Group Espresso & Coffee Maker Logo
184 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Eric Ramos
Eric Ramos
Tom Chichester
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
