Hotpoint fault f-07
My Hotpoint WT940 is flashing fault code F-07. I have cleared the ball float, removed a few coins but its still the same, any help appreciated. Thanks
  • Washing Mach... Master
  • 3,463 Answers
F07 means that the heater relay is stuck, you need to test the heater and replace if req'd.
If heater o/k then you still have a problem with the heater circuit somewhere.
Maybe a control assy
Plz rate this solution.
Thanks, and a merry xmas.
Posted on Dec 20, 2008
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
F-07 is flashing on my washing machine
If you have a Hotpoint, Creda or Indesit Machine the the F07 code means you have a heater fault and should check the heater, module and associated wiring. For more error code solutions click on the link
Mar 16, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Apr 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
425 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
