Question about Spectrum Digital Spectrum, inc U-30364 NuVue 5.6" Digital Photo Frame
Need help with my digital photo frame
I put the disk in...and all I get is a green screen with 3 options on it. I have tried them all....no pictures
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
My children gave me a digital photo frame for Christmas. I have a Nikon digital camera. I have downloaded and deleted from my camera several pictures I would like to put into my photo frame. Am I able to...
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Dec 29, 2009 | Coby DP-767 7-Inch Widescreen Digital...
Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Jul 31, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
Wanted to erase a single picture, accidentally erased all. Now, computer not recognizing frame, asking me to format removable disk before I can use it. Unable to reinstall. Before, computer recognized...
Yes, that's because you have deleted the files. The frame will work just fine. You can can rename 'removable disk' to PANDIGITAL but it doesnt really matter.
All you need to do is copy the images and it will show up on the frame.
Jun 09, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Digital Picture Frame Shows Black Bars
The nature of 16:9 basically means that you will be losing photo information in normally framed 4x5/5x7 photos. There is no way to fix this because the frame size of 16:9 is wider than 4x5/5x7. The options the frame offers are the only options to make your photos fit. Either crop, or distort.
The best solution is to keep this in mind when taking photos from now on and assume you will be cropping the top and bottom of the image.
As for the photos you have already taken, the only viable tactic to take is to reframe them for 16:9 yourself. You can download a free photo editing application like "GIMP" to do this. Create a new project that is 800x450 pixels. This will give you a 16:9 canvas. Next drag your existing photos into this canvas and move it around and resize it until you find a suitable framing for your picture.
Unfortunately it seems that as 16:9 solidifies itself as the new screen standard people are finding that shooting photos framed for 4:3 or in portrait dimensions are not translating well to this new standard. You may even want to consider returning this frame and looking for a 4:3 aspect ratio frame if cropping/resizing is not acceptable for you. Good luck!
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Cant get photos from computor to digital frame
Hi, i put the photos onto a disc, then transferred them to 13897 frame! I know it seems silly, but i was jst trying everything. Good Luck!!
Jan 01, 2009 | Sakar Computers & Internet
Customer service to help me to use quantaray by sunpak
I have a quantaray 15" photo frame and I cannot get the screen bright enuf to see the image.
Dec 31, 2008 | Quantaray 7-Inch Digital Picture Frame -...
Card read error on the digital picture frame - brand new. I bought this 7" digital photo frame from argos and I insert the SD card whilst the device is turned off, when I turn it on the message reads...
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Dec 12, 2008 | PANDIGITAL 7" Digital Photo Frame With...
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
Copy photos from pc
Look for an option when you open photo manager that says upload picture. Browse the locations then choose my computer, pictuers and click open the picture that you want in photo manager. Other wise, try to put/copy the picture in a new folder in you computer, then click cut and paste to photo manager.
Artgirl
Jul 20, 2008 | Philips 9FF2M4 9" Digital Picture Frame,...
Spectrum Digital Spectrum, inc U-30364 NuVue 5.6" Digital Photo Frame Logo
42 people viewed this question
Top Spectrum Photography Experts
pontelemon
pontelemon
Are you a Spectrum Photography Expert? Answer questions, earn points and help others
