Question about Saeco VIA Venezia
Nozzle won't stay on steam tube
We just bought the Via Vanezio and used it successfully to make 4 cups of cappuccino. However, during the cleaning procees we took the nozzle off the steam tube to clean it and now it won't stay on. We might have dropped a part in the process but can't find anything and there is no exploded view of the steam tube and nozzle to see if we're missing something. We have 4 parts, including the cover. There's a large collar with threads on the inside, a small collar (that doesn't seem to do anything), and the nozzle itself with the gasket to hold on the cover. The nozzle appears to screw into the large collar just fine but applies no pressure to the steel tub to hold it in place; it just slides back off the tube. Any help?
  • djg_horizon Dec 20, 2008
    NEVER MIND! We just found the rubber tube gasket that was missing and it works fine. It would help if the instructions included an exploded view of the machine assemblies.
There should be two rubber pieces inside the threaded collar & cap that help produce a pressure fit onto the wand itself. There is a total of five plastic pieces on my steam wand excluding the wand itself on my Via Venezia by Saeco I purchased a year ago. Sounds to me like you lost one of you rubber gromets! Just my thoughts!
Posted on Dec 29, 2009
Tefal repairs
follow this steps and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in wat
Nov 29, 2013 | Irons
Tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
on Feb 25, 2009 | Cuisinart ICAPP-4
The green light does not come on and it does not steam
follow this adjustment and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
Nov 04, 2013 | Oreck Steam-It Steam Wand
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
Model gh3000 spool will not release for removal
Clean an iron:
  1. Unplug the iron.
Oct 09, 2013 | Irons
Pump wont run
Clean an iron:
  1. Unplug the iron.
  4. God bless you
Apr 04, 2013 | Rowenta DG-980 Iron
How do I make cappuchino cofee?
If you are looking for a manual, you can contact Jura Capresso directly. If you are just looking for directions for making a cappuccino in general:
Brew the espresso.
Use the steam wand/frothing element and a pre-chilled frothing pitcher (the pre-chilling is optional, but it is considered good form) to steam about 1/4 to 1/2 cup of milk.
A true cappuccino does not involve pouring all of the milk directly into the espresso - you would use a spoon to take about two spoonfuls of the top of the steamed milk and place it on top of the espresso.
You can sprinkle cinnamon, use a cinammon stirring stick, or pour cinnamon cappuccino flavoring on top of the cappuccino for good form (but this part is optional).
Enjoy!
-Tha Mp3 Doctor
Mar 22, 2009 | Jura Capresso CapressoBAR 351 Coffee...
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
Feb 26, 2009 | Cuisinart ICAPP-4
NEED DIRECTIONS For Model ICAPP-4
I can answer just about any question you have on the unit - I wasn't able to find the manual online, but I would be more than happy to scan and e-mail you my copy of the original manual. In the meantime, here is my basic Wiki Manual:
-Tha Mp3 Doctor
Feb 25, 2009 | Cuisinart Coffee Makers & Espresso...
Steam Nozzle
I've only had it fly off once.  I think I didn't put it all the way on.  Also make sure you clean the nozzle every time you use the steamer.  Milk will clog the nozzle otherwise.  My maker is right beside the sink and I rinse the nozzle immediately after steaming milk.  I also run it through the dishwasher at least weekly.  (This isn't a substitute for immediate clearing of the nozzle.)   A clogged nozzle will always blow off the end.
Aug 12, 2008 | Krups XP4030 Espresso Machine
Saeco VIA Venezia Logo
198 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
