Question about Sony KDF-E55A20 55 in. LCD Television
PROBLEM EITH SONY TV KDF-E55A20
Hi my name is ramjeet and i have a problem with my sony tv modle #KDF-55A20 it went blank one night and when i try to put in on back it comes on green and then start to flash red six times i called a repair guy and he said the power board is gone and it gonna cost four hundred and ninty five dollars to fix it but from what i read for that problem is that the thermo fuse is blow and why are they telling me the whole board have to replace if any one have a solution for this let me know. thank you
  • Kentuck Nov 29, 2007
    I have the same problem. The red light flashes 6 times and according to the trouble shoot sheet--it is power overload. Is the same as a power surge.
    Steps to solve: contacted Sony and when they found my unit was only 1 year and 8 months old. they stopped communicating. I bought a new bulb. but that is not the problem.
    I think Sony has a quality problem
    Problem Solver:
  • 7 Answers
The problem is the thermal fuse. You need to have service bulletin to fix. I have seen other people have the same issue and it was fixed by getting the SB at agoraquest. It's a step by step guide on replacing the thermal fuse. The member that has the service bulletins is Jehill. He has helped several people with this issue
http://www.agoraquest.com/viewtopic.php?topic=24322&forum=34&start=0&select_page_number=1
It takes about 2 hours but saves over $400 in service repair bills.
Here are some of the people that were helped by this
J/K :-p ......worked like a charm :-) Took me about 2 hours and almost half of that was to go and get a 20" #2 philips screwdriver. A 12" would have worked, but they did not have it. Other than than that, no problems. I paid $220 for the TV, $28 for (2) Thermal Fuses, and $11 for a screwdriver. Now I have a decent 2nd TV :-) Not as good as my KD-34XBR960, but not much is :
Happy
I just got done replacing the thermal fuse as per your SB and all is well again! I, and most importantly the wife, just want to take the time to thank you so much for your help. With your instructions and this site, we have just saved ourselves alot of $$ not just for this time but also if it were to happen again in the future. I am truley grateful for finding this site and just want to say you are THE MAN!!!
pratt31
1 10" screwdriver $12.00
1 Sony Thermal Fuse + shipping $ 8.00
1 membership to agoraquest.com $12.00
Fixing the thermal fuse myself on a TV that was discarded at the curbside
PRICELESS
Posted on Apr 14, 2008
I am Kentuck, I had the same problem and through this site I ddecided to order the thermal fuse and replace it my self. They cost a bout $6.00 each, So I ordered 3 which with shipping and tax came to about $30 bucks.
I tried to buy a schematic from Sony, but they would not sell me one---Believe me this is and my last Sony product that I will buy.
Found the information I needed that the thermal fuse is located on the frame under the bulb. You must take the fan out to get to the fuse.
The next problem is the recognition of the fuse. There is a metal canster type and a small thermal head (1/16 X 1/4 X 1/4 inch and I am gusessing now. ) Follow this wire to the connector and disconnect and replace. I taped my thermal head down because it had no holder. It works fine, because it measures the temperature of the lamp. Gets too hot it blows.
My fix was $30 vers $500 Sony wanted. No more Sony
Posted on Apr 01, 2008
We had the same thing happen, it was the thermal fuse and cost us 400 to replace now it has been 6 mos. later and having the same problem. The part is only 22.00 but I am not sure I can replace it myself without messing up something else.
    Sergeant:
    Champion:
  • 231 Answers
Yes thermal fuse is probably the problem about ($11-15).But the problem with that is that some repair shop just replace then .Without cleaning the fans in unit .The thermal fuse can easily blow again causing the same issue.The fans get crusted with dust and do not venting out the heat from lamp properly causing overheat then leading to melted cabinet part or thermal fuse issues...
Posted on Nov 30, 2007
I had the same problem, with the light blinking 6 times...it was the thermo fuse...the tech replaced it and I think it was around $200 for the part and repair together...That was about 6 months ago and I havn't had the problem again. I also have the KDFE55a20
Posted on Nov 09, 2007
    Genius:
  • 1,074 Answers
If your set is going to cost you $495.00 to fix it then you might as well buy a new tv which will be cheaper.from my experience that tv will only cost about between $75.00 to $200.00 to fix.get an estimate from another tech have them take a look at it.before they repair.and let me tell you that it is not the whole power board needs to be replaced just the regulator and some other components.good luck.
Posted on Apr 02, 2007
I have the sony bravia KDF E50 A12U The tv went pop and wont work. On switching on the tv, the light stays green, then goes over to 3 red light flash then green. What is this and is it easily fixed?
  • This model had a problem with the lamp door warping from the heat.
Remove the door and hold it edgewise to see if warped..
There is a peg on the back of the door that engages a lever when the door is closed---if door warped set will not come on.
A simple way to confirm or deny this is to use something not metal to with the door removed ENGAGE and hold the lever forward.
DO NOT IF THE THIS SET COMES ON LOOK AT THE LIGHT OR OPERATE IT FOR PROLONGED PERIODS OF TIME.
Do not put the outer shield cover back on without the door as heat can get it also.
If set comes on with door lever engaged you need to replace the door--widely available on the internet and or from Sony---not a bad idea to buy a spare one.
let me know what happens.
Mar 15, 2012 | Sony KDF-E50A12U 50" LCD HDTV
I HAVE REPLACED MY BULB OM MY KDF-50W655 AND MY TV IS WORKING AGAIN, BUT I HAVE TRYED TO RESET THE TIMMER TO THE BULB THRU NMY CONTROL....BUT CAN'T SEEM TO MAKE IT WORK...
I have installed the new lamp and the the led power light comes on green and than turns flashing red. What is the next step in this repair?
Mar 21, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-E55A20 55" 3LCD TV Purchased
Hi This is most likely the inverter panel that drive the CCFL's (Backlight tubes) or the backlight tubes themselves, I'm afraid I can't help with the diagnostic test or service menu.
hope this helps
Midge.
Feb 10, 2011 | Sony KDF-E55A20 55 in. LCD Television
I have a 60" Sony
It seems lamp/ bulb popped again, check lamp inside tv.
If tv does not show red blinking light then it would be lamp that knocked off, replace lamp in tv to fix its problem, please buy Sony original lamp for good picture in tv.
Let me know if you have additional question.
Thanks.
Jan 15, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
MY SONY KDF E 55A20 REAR PROJECTION TV HAS THIN RED VERTICAL LINES ON THE RIGHT SIDE..HOW DO I FIX THAT
You need to replace the optical block to fix this problem it sounds like one of your LCD chips is burning out and that is why you get this kind of side effect the OPTICAL BLOCK usually runs around $230.00 - $350.00dls plus labor here is a guide if you want to replace it on your own
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Oct 04, 2010 | Sony KDF-E55A20 55 in. LCD Television
Screen turns off and on Sony KDF E55A20
It is symptom of dying lamp and tv requires new lamp.
Existing lamp in tv has reached to end of its life span and causing that problem. If lamp has not been replaced in last 2-3 years, just put new lamp in tv to get it back in business.
Thanks.
Jul 28, 2010 | Sony KDF-E55A20 55 in. LCD Television
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
Sony KDF-E55A20 55 in. LCD Television Logo
2,137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
