The belt broke on my top loading washer, and when I took the front panel off there is a lot of oil sprayed around under there. Not puddled up but sprayed none the less. Before I replace the belt, any idea where the oil came from? John
  • 179 Answers
It came from your transmission once your transmission runs out of oil, its done for time to buy a new machine
Posted on Dec 20, 2008
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
I have a GE stackable unit and I recently broke the belt on the washer- I think. Can I fix it? How do I get the unit open? Thank you for any assistance you can give.
Two screws on the very bottom, remove them and take something flat and insert it in the crack where the washer top is and the front panel. The front panel will slide down and out towards you...if no water is in the unit then push the tub back towards the rear and the motor will lift enough to work on it, replace the belt around the main pulley and then push the spring loaded pulley towds the left towards the main pulley and slide the belt onto the motor pulley...
Apr 10, 2011 | GE Spacemaker Washer and Dryer Electric...
GE Washer Mod # WJSE4150 click on spin cycle when fisrt engaging, seems to run & spin fine when in second/hiher speed.
Hi, since your washer is a "belt" drive, I'd suggest checking to see if perhaps the belt is slipping. While you're checking that, make a note of "oil" sprayed around the cabinet on the belt, pulley's etc. These generation GE units are known for tranny leakage/failures. If you're able to remove the front panel from the cabinet, you'll get a much more thorough look at your drive & basket/tub assembly. Just push in the 2 clips on top of the front panel on both sides with a puddy knife or narrow flat screw driver, and pull forward. The bottom just hinges on 2 hangers and the front comes right off. That's a start for now, hope it's a help. Let me know. Good Luck :)
Oct 28, 2009 | GE WJSE4150B Top Load Washer
Belt broke
If you can see the belt and there is not a cover under your machine, you can simply remove the belt and replace. However if you have a bottom cover, you will have to remove all exterior screws around the front and sides of the machine. There are several, this will release the cabinet so that you can remove the cabinet and get to the belt to remove and replace.
Jul 05, 2009 | Amana DLW330RA Top Load Washer
How do I replace the washer belt
Remove the front panel to the washer. Screws across the bottom. Push down on the front panel, then pull it out. Belt should go around transmission, motor pulley and tension roller.
May 13, 2009 | Frigidaire MET1041ZA Top Load Stacked...
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Oil leaking from washer
if it smell like wd 40..your transmission is defective,,need help replacing post question,,
Dec 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
Take apart washer
just remove back ...don't remember seeing broken belt on duet except the sport far as control panel remove top a couple of screws top front and snaps in at bottom but IF AIN'T BROKE DON'T FIX IT
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Replacing Belt on Jenn Air CLothes dryer
1. Disconnect power
2.Use Putty knife and push in to release two spring catches between top and front panel about 3 inches from either side. Top then lifts up. Undo two hex screws on either side of side panels close to top. Front panel then tilts forward. Un-clip door switch and wiring harness before lifting off front panel. If belt is broken, drum should lift off by slowly raising front of drum to disengage wheels at rear of drum.
3. clean accumulated lint from inside fan housing and duct work on front panel as well as from total inside of dryer base before placing new belt around drum, smooth side up before carefully replacing drum in place to engage two wheels at rear of drum.
4. reaching left hand under drum, raise spring loaded idler arm and place ribbed side of belt around pulley on end of motor with right hand before releasing idler arm to provide tension on belt.
5. Place front panel on bottom clips and reengage door switch wiring harness before reattaching hex screws at top of side panels.
6. drop top pannel of unit in place to reengage spring clips before reconnecting power
Dec 24, 2007 | Dryers
Washing Machines Logo
Top Washing Machines Experts
