Question about Hitachi 53UDX10B 53" Rear Projection Television
HITACHI 53UDX10B Projection TV: Convergence Board
Regarding the removal of the Convergence board... How do you disconnect the "bridge-like" leads that connect this board with the circuit board to the left of it? Or do you not need those if they break? I am just concerned about those.
  • tgr12865 Feb 08, 2009
    what is converengce do i need a repair person to do this
  • 3 Answers
They just pop off ~ pull up and out on the right side of "bridge". Then just fold carefully up and our of the way so you can get at the board. You do not have to remove both sides of these. Very simple ~ just becareful not to twist so you're not bending and weaking the wires.
Posted on Aug 10, 2010
Hitachi 53udx10b screen is dark, very blue and red. there is a red wave across the top of the screen. there is a blue "ghosting" of any text on screen.
The tv have a problems known as a convergence picture problems,it is dead.Tv set have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to causes all these problems.Now the tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set convergence pictures promblems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Hitachi 43UWX10B 43" Rear Projection...
I see three pictures blurred together in different colors almost like its out of focus but unable solve with controls
The tv have a problems know as a convergence problems,it dead.The tv convergence board require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence board,to solved the tv convergence problems.The shop,will cost $300-350 for parts and labors.
Sep 16, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi projection tv 53uwx10ba - the Convergence ICs were replaced. When the PDKP bridge between convergence board and 2nd board is plugged in, it makes a noise. Kept that unplugged, the picture is...
Did set have this problem before you replaced the STKS?
I know these sets very well. If problem is different in any way from before you replaced chips.......double check all soldering or one of the new chips may be defective.
The more you tell me the better I can help.
regards, SD TECH
Aug 18, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Blue lines across screen with mirror images
Try adjusting the convergence. If it won't move see below
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 28, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Help! It's stuck. Stubborn Convergence board.
Did you remove the screws off the board.? That should do it. !!
Jan 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Removing the JK07132-A convergence board
Unplug TV from ac outlet for few hours, this will discharge caps in circuit boards and you can take out desired board after unplugging connectors.
Always Be Careful while doing repair in TV.
Dec 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53udx10b v1j013720
More than likely it is a convergence problem. Best way to tell is to unplug the plugs marked red conv, blue conv, and green conv. Careful not to unplug yoke plugs by mistake, and make sure you mark plug and board when disconnecting. If convergence amps are the problem, set should power up with convergence plugs disconnected. Do not leave set playing very long. This is just to verify problem. Your welcome, Russmann.
Nov 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultravision 55 inch
Check to make sure you reconnected the jumpers to connect the board that you removed. Also, check to make sure no resistors are burning. If still no pix, make sure you reconnected multi pin plug by digital convergence unit (DCU). Next, disconnect conv. plugs marked red, green and blue. This should allow power to come up if chip(s) are bad. Next, check pico fuses on board by jumper connectors or in power supply. If these are open look for solder bridges around conv. amps. Also, if any of these are open check all zener diodes beneath heat sinks where you installed conv. amps. Probably 27 v glass zeners shorted if solder bridges were created when changing chips. Good luck, sometimes you just get a bad I.C,Russmann.
Nov 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B Power Light Flashing after convergence IC replacement
C603 is a polyestor capacitor 0.068UF-FEB 50V part number 0880047R S901 is the power relay ALKS329 the part number for the relay is FJ00142 . I recomend checking the pins on the ICs to make sure they are not bridged. If you need more assistance let me know. Vance Baldwin should have the parts if not you may have to order through hitachi
Jun 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitaci 53 rear projection
ohhh boy very carefully, i released the wires from around the holders to give me room and disconnected the ones that didn't stretch enough then removed the screws around the black holder that holds the boards and lifted the board up and unsolded the head sink and then the ic's
check out these liks for pics and better explainantion
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Dec 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
