Question about Itochu C.itoh CI 5000 Matrix Printer
Home Error Hi, I have a C.Itoh 5000 Printer, am receiving Home Error. Carridge is not returning to home position. This printer was monunted in a vehicle with a power converter There was a problem with the converter before the error occured. I swapped the printer chassie with a known good chassie and still received the error. There is a very good chance the main board took a 'hit' but I can find no burnt componants. All other systems seem to be working from control panel (I can change settings...) Is there a way to check/change out the home sensor? The manual I have, from C.Itoh, is no help. Thanks in advance, GTW
    Problem Solver:
  • 17 Answers
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
Posted on Mar 25, 2008
The printer will not print I receive an error message
undr the scanner the is a lock.Unlock it...it looks like a switch.The scanner does not righ the home position
May 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
Scanner belt slipping
Check flatcable connection to main circuit board:
Open cover and release the "Z" cover (right side) which hides the flatcable. Simply stick the cable to mainboard.
Feb 20, 2008 | Brother MFC 240C All-In-One InkJet Printer
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Error Message SC471 for my Richo printer
Hi there the following is taken from the service manual hope this can help you.
471 Belt tension unit cam error
Even though the belt
tension unit tries to return to
its home position several
times, the home position
sensor is not activated.
• Defective transfer belt unit
• Pin 3 (CN25 on engine control board) unable to
send signal
• Defective transfer belt tension unit
1. Replace the transfer belt unit.
2. Replace the engine control board.
3. Replace the transfer belt tension unit.
Thanks J
Nov 18, 2007 | Ricoh Aficio CL2000N Laser Printer
Error code A21
Aug 30, 2007 | Itochu C.itoh CI 5000 Matrix Printer
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
199 people viewed this question
Top Itochu Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
