Question about Garmin Nuvi 350 Car GPS Receiver
Battery Charging, Nuvi 35
How long should it take to fully charge the battery on the in-home charger should the unit be in the off position.
  • Garmin Master
  • 2,130 Answers
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Posted on Dec 20, 2008
My Garmin Nuvi 1300 is turned off and charging. It charged all night and still says its charging. Will it ever read fully charged?
Most likely not. I've been repairing the 1300 series for several years and I've never seen it. The older units would say "battery charge complete". I would go by the green battery icon in the upper right corner of the screen at the main menu. There should be 4 green bars to be fully charged. Of course to see them, you have to unplug the charger.
Sep 11, 2013 | Garmin nuvi 1300 Car GPS Receiver
When charging my Garmin 265WT, is the screen supposed to show when the battery is fully charged? e.g. charging complete
While it's charging it doesn't show the battery indicator. When the charger is plugged out it shows the battery state on the screen that shows WHERE TO and VIEW MAP
Feb 25, 2011 | Garmin Nuvi 265W GPS Receiver
The battery status indicator does not show on my screen. I can only see it when I first turn on using battery power. It doesn't show me anything when it's charging, or how much battery life I have left.
The indicator goes away telling you that its no longer running on battery power and that its running on the car or AC charger. During that time, its charging the battery. Only when you remove the unit from the charger/adapter will you see the battery icon because you will then be on battery power. 4 green bars mean you are near or fully charged.
- Jim
SHARCNET-USA
Oct 07, 2009 | Garmin nuvi 265 Car GPS Receiver
Nuvi 750 wont turn on even when i hold the on button for a minute or more
Looks like the in-built rechargable battery is fully discharged. Try charging it for good amount of time like more than an hour through Car or computer charger. Keep the unit off to maximize charging.
Oct 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Nuvi 200 when charging never says charging complete .
HI, I have the same NUVI. Mine does the same. I haven't had any issues with it. It still charges fully when I unplug it.
Jul 25, 2009 | Garmin nuvi 200W GPS Receiver
Not knowing when my nuvi 250 is fully charged
if the greens bars on the upper right indicates fully charged
Nov 29, 2008 | Garmin nuvi 250 GPS Receiver
Charging a Garmin Nuvi 260W
Generally most batterys are left on the charger overnight, thats a good way to ensure a full charge, but as you will be using it in your car, it doesn't matter much as power is always available.
To ensure best possible battery life when you have a brand new battery, charge it fully and then drain it almost to 0% Draining most batterys into 0% will be harmfull instead of helpful, I assume the nuvi uses a Li-ion battery so draining it fully is not a good idea, drain it almost fully and then charge it fully.
And you are good to go, repeat the process if you leave the unit unused for a month or two for best battery life.
Thank you,
IwillFixIT!!
Nov 15, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Nuvi 250
Have you used the wall charger to fully charge the battery? If the battery is too low after lying around for a month it wil not start, giving it a couple of minutes of charging wo'nt help either, a good and full charge will!
Mar 29, 2008 | Garmin nuvi 350 GPS Receiver
I have a nuvi 200 that wont run when it is hooked up to a power supply
The Nuvi 200 only has a 5 hour battery. Once charged, it can be removed from the charger, but the battery will only last 5 hours. Can you plug it into the car charger and navigate while charging BEFORE the battery dies? If so, and you don't have to remove the charger, you can leave the unit plugged in while you navigate without damage to the unit.
Feb 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
374 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
