Question about Dell Latitude D600 Notebook
The battery light is amber when the adapter is plugged in.
My laptop would never work without the adapter. For some reason, now even with the cord in the battery light still glows yellow (or amber). I can't power it up now. I'm so frustrated and I just someone to tell me I won't have to get a new battery.
  • 55 Answers
Sorry to be the bearer of bad news here but the amber or yellow light means 1 of 2 things. The battery is bad or the battery charging circuit on the motherboard is bad. Normally it is the battery and replacement would need to be purchased.
Posted on Dec 20, 2008
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
When I plug in my HP 530 Green light comes on then turns to amber. Will not come on even when I remove battery and just plug in. 1322dijim@gmail.com Posted by Guest on 7/5/2012 Details My notebook wi
The amber color of the light is an indication of a motherboard malfunction ..and this is the reason it does not work ...It can be something related with a poor contact or a CPU issue ..but usually when this light is on ...it means you need a motherboard for it cause the one in discussion is dead ..
Jul 05, 2012 | HP 530 Notebook PC
I tried to power on my computer and there was nothing. It was plugged in and the battery light was blinking amber when I tried to press the power button. The light on the power cord is green but there is...
It sounds like the Power adapter is:
1. Not plugged into the computer
2. Not functioning
3. Has a broken connector (or the laptop has a broken power connector)
Unplug the adapter, remove the battery, hold the power button on the laptop for 30 seconds. Plug in the power adapter connector to the laptop - if the power indicator illuminates, remove the power cord, insert the battery ant then plug in the power cord. Press the power button (hopefully you're back in business).
If that does not help, p borrow an adapter from a friend and try it with your laptop, if it works, then go buy a new adapter!
Sep 05, 2011 | Acer Aspire 7740G6364 (lxplx02165) PC...
Dell Inspiron 5160. When plugged in then power light lights up (before hitting the power button like my 5150) and the battery light is amber. The 5160 will not do anything - not power on at all.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 26, 2011 | Dell Inspiron 5160 Notebook
Battery of my Acer Aspire 4810T does not work. With the power supply plugged in, the indication of the battery is "85% available (plugged in, not charging). If the power cable is disconnected, the...
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
1.
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
CARLO
Apr 13, 2011 | IBM ThinkPad T40 2373 Notebook
When connected to AC adapter the amber light for battery doesnt change to blue even after full charge.
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty. If the battery indicator flashes amber or is a steady amber, the
battery will probably needs to be replaced, since it's not charging fully.
Hope this helps.
Apr 13, 2011 | Acer Aspire One Netbook
Unit will not power on// has a solid amber light// turns green for about 3 seconds then back to amber
You may have a bad DC connector:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 17, 2010 | IBM ThinkPad T20 2647 Notebook
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Powerbook G4/17. Had been running on battery, now dead
Hello, You can test your adapter using a voltmeter and see if the power comes in Best regards. The best is actually to test with another adapter
Jun 10, 2009 | Apple PowerBook G4 Mac Notebook
Problem with extended battery
LED indicator for your laptop model
Steady Blue = Battery charged and AC adapter plugged in
Amber = Battery charging and AC adapter plugged in
Slow Amber Flash = <10% battery life
Fast amber flash = 3% remaining TPC will automatically go into hibernate
Slow flashing amber Adapter plugged in = Overheat condition
Do you have a multimeter to test the battery that you are using? check the output current of the battery.
May 29, 2009 | Motion Computing MOTION LE1600 Notebook
Dell Latitude D600 Notebook Logo
144 people viewed this question
Alun Cox
