Question about Vizio VU37L 37 in. LCD TV
My vizio VSC-37V1 will not turn on.
When I plug in my Vizio 37" LCD TV the power light turn orange. I then push the power button and the light turns blue blinks one and then nothing. The power button will not respond and the light next to the power button stay blue until I unplug the unit. The first time it happened I was able to unplug the unit, wait 10 second, then the TV worked normally. The following day the light next to the power button went orange when the unit is plugged in, when I push the power button the light turns blue then blinks then stays blue. The screen is black, no sound, and the power button and remote have no effect. Which computer board needs to be replaced?
what is wrong with this 22 month old tv?
  • 2 more comments
  • letorpey Dec 22, 2008
    THe TV becomes unresponsive. I am unable to turn it on or off or pull up a menu or change th source, I tv was always plugged into a surge protector which was chaged from time to time. The first solutions I received were not helpful to the problem I posted. Please help me fix my TV.
    power is going to the television. the powr button is turning the tv on such that the poer indicator light is turning blue then nothing. will not turn on or off, no menus, no responsiveness to the power button. the light just remains blue for ever. I unplug TV and the power indicator light turns orange. I turn on the TV using either the remote or the power button on the tv and the light turns blue the again unresponsive and says blue forever. Please help
    is there any way to evaluate the boards, diagnositic testing, voltage, etc
  • DENNIS MITCHELL Feb 08, 2013
    go to Ebay.com search using vizo VSG27V1 Powers supply or go to www.shopjimmy.com
  • Vizio Master
  • 19,396 Answers
Either you can either fix this in a quite simple way, or you need send this to a repair facility (more likely).
The led coming from orange to blue, with tv not responding means that tv is on Protection. This is a special diagnostic mode that is started automatically whenever an internal fault is detected.
That means that the power surge caused a fault.
If you had been lucky enough the problem may be due to electrostatic cahrge accumulating on power board capacitors.
In this case you fix the problem leaving the TV unplugged (cord not connected, turning off is not enough) from power for one hour or so. That should be more than enough to find out, since this TV does not have high voltage circuits apart the inverter board.
If it does not restart, that means that there is an internal fault, and for real. This can be a commonly blown capacitor, another component had blown, that happen commonly after a power surge.
Regarding the main board, that is called controller board (Visco LCD Controller 05A20-1B for model VSC-37V1 ), this is only rarely damaged by a power surge. More exposed to this kind of damaga are the power adapter/power board, and the inverter board (Visco Back Light Inverter VIT71010.52 for model VSC-37V1 ).
Also Signal board resistor and capaitors on input/output boards can blow during a power surge.
Leave tyhe TV power cable unplugged for a while, if this does not fix it, call for service.
Posted on Dec 22, 2008
  • Ginko
    Ginko Dec 22, 2008
    The way to test the TV is by taking it apart , checking for bulged capacitors, or component the have blown by sight.
    Then you grab the service manual and try to understand the possible fault, following diagrams, and testing components with a multimeter, then you find the defective part and replace it.
    If this happened after a power surge, leave the TV unplugged for a while. If that does not work, better calling a technician.
    Scholar:
  • 61 Answers
I own several Vizios and it might possibly be that you have the wrong input selected. Try to use the remote to put it onto a different input or on the side there should be an input button, put a dvd into the DVD player that you know works and put it into the normal analog rca cables. Then, push the inputbutton until you hear sound or video. If this doesn't work than there is a possible power supply problem with the T.V. or the main board has gone out.
Please email me back if none of the above suggestions helped.
  • 10,594 Answers
Symptoms shows digital processing board is defective because TV doesn't respond except power button.
Digital processing board is usually known as main board having system control, input selections, tuner etc.
    Brigadier General:
  • 5,158 Answers
You mention a surge protector... is it also a power back up in case the power goes out... make sure if you are doing a reset to the tv by unplugging it.... that you unplug it from the surge protector.
Robert
  • 3,037 Answers
Hello letorpey
The main board is the most likely problem when this happens. 9 times out of 10. Order a new one from Vizio. They have great customer service. Good luck on the repair and if you have further questions, please let me know
bestdarngood
  • 4,806 Answers
Hi there
Try to reset the surge protector
regards
    President:
  • 2,110 Answers
Make sure the video cable supplied with the TV is secured to the correct video
output port on the back of the VCR and the TV. Make any cable you have attached
to the TV is secured to the correct output your Set-Top Box, DVD, etc.
Adjust brightness and contrast.
Check Source settings
Or
Make sure that the power cord is plugged into a grounded electrical outlet.
Make sure that the power button is turned on.
Make sure that the selected input source is connected to a working input source.
If your TV is connected to your computer in RGB or HDMI mode, press any key on
your keyboard to “wake” your computer
Posted on Dec 20, 2008
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
When I turn our tv off the vizio emplem stays orange
According to the manual. It says The Vizio lights white when powered on and orange when powered off.
Mar 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
May 06, 2009 | Vizio VW37L 37 in. LCD HDTV
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VU37L 37 in. LCD TV Logo
446 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
