Question about HP Photosmart R507 Digital Camera
Stuck in docking mode
My camera is new and was working fine until it was unplugged from my computer without safely removing it from the USB port. Now it is stuck in docking mode, ive tried leaving the batteries out and takeing the memory card out. Ive also tried plugging it back into the computer and safely removing. Is there any other way of resetting it or fixing it? Thanks,
    Scholar:
  • 121 Answers
There may be a small reset-button hidden inside a small hole somewhere that you might push with a paperclip or something. Also make sure the connection plug on your camera isn't damaged. If some pins are shorted out it might fool the camera to believe it's still connected to the computer.
Posted on Apr 03, 2007
SOURCE:
I unplugged my Nikon D80 from the computer without clicking the safe to eject drive button and now it seems to be stuck in PC mode!
Try resetting the camera by removing the battery for 20 mins, then replace the battery and go to the Menu setting and set the Date and time.
May 27, 2012 | Nikon D80 Digital Camera with 18-55mm Lens
My keyboard is locked how do i unlock it?
Maybe you keyboard is bad or your keyboard has been hijacked by a virus.
Make sure you keyboard is plugged in good on the back of the computer. If the end of your keyboard that plugs into the computer is Round and it plugs into the green port on the back of the computer you have a PS2 (serial) type of keyboard and you cannot unplug it and expect it to work if windows has already booted up. If you remove this type of keyboard connection, you have to Reboot your machine otherwise the keyboard is locked.
If the end of your keyboard that plugs into the computer is Flat, then you have a USB type of keyboard that goes into the computer's USB Port. This type of keyboard is Plug and Play so you don't have to reboot if you remove it. If you have this type maybe the USB Port you plugged it into does not work, so try plugging into another USB Port.
Try booting in Safe Mode and see if the keyboard performs.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 09, 2012 | Acer Computer Aspire AM3800-U3802A Desktop...
Keyboard locked
Apr 09, 2012 | Acer Aspire Z5700 PC Desktop
Usb port doesnt work on toshiba satelite l300
Based on the information you have provided, it seems that the issue might be Hardware related.
All the USB Ports use a common driver. As all the other ports are working fine, its clear that the issue is not with the USB Driver.
It very much looks like the port which you have mentioned above is faultly.
Hence, it would be better to contact the authorized service center to have a detailed check on the Computer.
Please feel free to contact for further assistance.
Hope this helps.
Mar 27, 2012 | Toshiba Computers & Internet
Screen is blank; can not see image with computer on
STEP: Toggle the Video Mode with the <Fn> and <F8> Keys
Additional Information
Press the <Fn> and <F8> keys to toggle the display mode between the video modes (LCD Only, Monitor Only, and Both).
STEP: Determine if an external monitor is being used.
Determine if an external monitor is connected to the docking station.
STEP: Determine if the video problem occurs outside of the docking station.
View the LCD panel on the system to determine if the same video issue occurs while the system is outside of the docking station.
STEP: Remove Any Docking Stations or Port Replicators From the Computer
STEP: Unplug All Accessories From the Laptop Computer
Unplug any accessories from the laptop computer, such as PCMCIA cards, external mice, external keyboards, external serial or parallel port devices, external monitors, external USB peripherals and port replicators.
Apr 23, 2009 | Computers & Internet
Can't re-install 2Wire USB Wireless adapter
If you are on windows vista it could be your driver. You can go into safe mode on the computer with F8 while the computer is starting up, then go to the control panel and device manager. Plug the adapter in and remove the driver for it. Download a new driver at http://support.2wire.com/index.php?page=download and install it.
Mar 30, 2009 | 2wire HomePortal 100W (1000-400026-000)...
Just installed a microsoftwireless keyboard 4000 and installed software and it worked fine. When I rebooted my computer would not start untill I unpluged the new keyboard. Tried several times to the same...
Hello There,
This problem is not common,
Try these:
1) Re-install the software - see what happens.
2) Un-install the software if 1) doesn't work and try using keyboard.
3) Read about common problems in the software and keyboard:
http://support.microsoft.com/kb/258826
4) If all these fail then call Microsoft about this problem and let them diagnose it. They are the makers so they should know what to do.
Dec 27, 2008 | Microsoft Wireless Laser Desktop 4000...
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Digital Camera - M425 - Stuck in review mode, won't switch to capture mode
I just fixed my daughters camera with this problem. First go to the capture mode and see if the reason you are in review mode is because the camera thinks it is docked. If so, look at the dock port on the bottom of the camera. ( May need to magnify it to see in there ) Look for any green corrosion between the contacts. Her's has this corossion between two pairs of the contacts. I took a jewelers screw driver and scraped out the corrosion and then blew canned air in there to remove it. Turned it on and now it works fine. I have a feeling that the battery compartment is venting through this port and the small amount of acid vapor produced as the batteries discharge is causing the contacts to get this corrosion.
Jan 13, 2008 | HP Photosmart M425 Digital Camera
Freezing / no recognition by computer
there is a reset hole in the back of your p2 sumsung
Dec 27, 2007 | Audio Players & Recorders
HP Photosmart R507 Digital Camera Logo
200 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
