Question about HP LaserJet P3005n Printer
57.03 Error in LaserJet P3005
How can I solve this Error?
the printer say "to continue turn off then on"
I do it but it still not work
then the 57.03 Error apper again in the printer screen
thanks
  • 32 Answers
One of the fans are not working. Unfortunatly, HP printers are not the easiest printers to fix. I reccomend having a certified HP technician repair the broken fan. If the printer is still under warranty, contact HP. They will either send someone out to fix it or replace the unit.
Posted on Dec 20, 2008
  • Boots66 Sep 16, 2011
    Sept 15/11 - Just finished putting in a maint kit into this P3005DN and it's late and it worked in the shop - took it to the user's desk and I get a 57.03 - Didn't help that the error meant nothing to me at that moment - but started to and removed the fuser just in case - 57.03 says a fan is not moving - no access to any fans via the paper path - so I tried to spin both fans, one on either side of the printer - the left side should move - Until a staple fell out and into the 'cup' below the fan - problem solved - no more 57.03 - Take the moment and do some common sense troubleshooting and as usual KISS or MISS and if your have any technical ability, you know what those mean
Got the same message. Turned printer off and on and message reappeared. 2-3 times later, I turned it off for a longer period, then on, and then message was gone.
Posted on Dec 06, 2010
Error 57 03
Buen dia un favor, tengo un aimpresora hp laser 2410 y me sale error 57,03 me podrian haer el favor y me colaboran?
GRACIAS.
Jul 23, 2013 | HP LaserJet P3005n Printer
P3005 13.05 error only when duplexing Lead edge stops at but not in fuser rollers Fuser has been replaced no odd noises
While going back, the paper not grabbing properly due to paper out roller got warn out, just file and make it rough on the surface, problem will solve.. You can see the paper out roller where paper coming out..
Jul 19, 2011 | HP LaserJet P3005 Printer
Error 57.03 on Hp Laserjet printer P 3015
Fan FM2 not working or jammed.location: remove left side door. you can see the fan..If jammed make it free, if its not working replace it.
Jul 06, 2011 | HP LaserJet P3005n Printer
Hp laserjet 3005 Problem : 49, 2f9d Error Power Off Then On Not able to continue the printing. please give me the solution for this problem.
Hewlett Packard 49.XXXX Errors
I hope this will be of assistance to you, any repairs under taken are at the owners free will.
Hello, the dreaded 49.2F9D Error Turn Power On/Off and other related 49 Errors.
This tip relates to the Hewlett Packard P3005 Series Printer - General reference to most HP Laser Printers
There have been many reports of this error in the HP genre of laser printer. This is a generic fatal error; the root cause is undetermined in most cases. It could be related to an application "corrupt data" or faulty printer firmware, or the formatter board or other associated hardware or accessory. The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. A new firmware file can be found here. P3005FIRMWARE
Pay close attention to PDF files with embedded JPEG files.
Pay close attention when printing Emails or Web Pages.
In rare circumstances the fuser has been reported to cause the 49.2F9D error. (P3005 specifically)
*** Further Reference Material MoreOn49Errors ***
Contact a local HP Authorized Service Center for further assistance.
Feb 21, 2011 | HP LaserJet P3005 Printer
Error 49A What does this mean?
Hi! I will be glad to assist you. If this is your issue, here are the steps you need to do:
HP LaserJet P3005 Printer Series - Service Error 49.0E00 when Printing PDF Files from Mac 10.5
Issue
A Service Error 49.0E00 message appears while printing PDF files from Mac 10.5 with the EconoMode setting enabled from the printer control panel and using the printing presets with the EconoMode setting disabled.
Solution
Recommended action:
Disable the EconoMode setting from the printer control panel (the default setting is OFF ).
Select printing presets with the EconoMode setting disabled.
Try performing a test print from PDF files in the computer to check for the results.
NOTE: If it is required to use a printing preset with the EconoMode feature turned off, ensure that EconoMode is set to OFF from the printer control panel also.
or you can go to this link:
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=1846089&productBigSeriesOid=1846087&spid=1846090&pname=HP+LaserJet+P3005+Printer&opname=HP+LaserJet+P3005+Printer&pname_desc=HP+LaserJet+P3005+Printer&st=1&ptype=commercial&stype=pn&qry=Error+49A&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+P3005+Printer&cqry=&uqry=&product_line_code=PQ
Oct 05, 2009 | HP LaserJet 3055 All-In-One Printer
In HP LJ p3005 DN Printer when i given to selftest continious blank page comes i have checked using change scanner assemblay and formetter but problem not solved pls suggest what to do
try removing the cartridge shutter, maybe is not opening. if after that you continue with the same issue without any errors there's a chance it would be the power supply
Aug 18, 2009 | HP LaserJet P3005 Printer
Error message 52.00
HP LaserJet P3005 Printer- just changed toner and now service error displayed, tried to power on/off still not working??
May 14, 2009 | HP LaserJet P3005 Printer
Error code: 49.2F9D
ok, go to the link to fix your problem--
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
Nov 27, 2008 | HP LaserJet P3005 Printer
HP LaserJet P3005n Printer Logo
4,079 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
