Question about Philips VOIP8411 IP Phone
Philips VOIP 841 - Change Skype Account
I am using a Skype account with my Philips VOIP 841. I just purchased a SkypeIn number and would like to set that number up to work with the phone. How do I do this?
Your skypin number should be associated with an account on skype. So all you have to do is to login using the associated account when you turn on your phone, do this by using the phone's controls to enter in your skype account and password.
Posted on Sep 17, 2009
How can i talk free using internet
You will want to use a VoIP (Voice Over IP) services or application.
  • Skype is the most mainstream (free) version. It allows instant messaging, video chat, as well as the ability to do voice only (i.e. making a "call"). If you want to make calls to an actual phone, you will have to purchase some credit but it is reasonably cheap. ( www.skype.com/)
  • Google's Gmail has integrated video chat
  • Google Talk also supports VoIP
Feb 28, 2011 | Computers & Internet
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
How do i use skype?
Skype is a great way to communicate.. I prefer it over other programs as it better suits a traveling person.
  1. Open a Skype Account. Go to www.skype.com
  2. (Computer->Computer) Search for your friends online. Add them by (Contacts / Add Contact). This is a free service
  3. (Computer->Phone). This is called SKYPE OUT. You can dial any fixed or mobile phone anywhere around the world if you add credit in your SKYPEOUT account (go to www.skypeout.com). Paypal and Credit card are supported. You can either add 10 EURO or 25 EURO at one time. Calls are cheap (depending on country), and are relatively comparable to IP cards. Remember to dial the country prefix!
  4. (Phone->Computer). This is called SKYPE IN. This is a VERY convenient service. SKYPE IN (www.skypein.com)allows you to reserve a phone number in a country of choice. The cost is 30 EURO a year, or 10 EURO for 3 months. This allows you to hand out a local number to friends / work collegues in a different country (so they are charged only a local call), and when they call you, your SKYPE on your computer will ring (no matter where you are in the world!). This is handy if you want to have a number on your business card for a country that you do not reside. The only cost to you is the yearly rental of the number, and the caller is charged a normal phone call charge.
Things You'll Need:
  • You'll need a Headset with a Microphone. The best to use is a set with the TWO plugs (microphone and speaker). Avoid the USB type headset (these can be painful when trying to remove the device). Th
  • You'll also need a Credit Card if you want to use SKYPEIN or SKYPEOUT
  • A computer! Preferably a newer computer with a better-than-modem connection.
  • Optional - WebCam. Version 2.0 and later supports video. Although not particularly flash - its still pretty cool (remember you'll need a fast internet connection for video)
Oct 25, 2009 | Skype IM
I want to use skype to fax from a brother 9440 printer, Can this be done?
Currently, this is not possible using Online Numbers ("Formally SkypeIn").
VoIP codecs like G729, use compression which means what goes in at point A does not come out always at point B.
This is not good for a FAX which depends on bits and bytes to remain the same from point A to point B. It would simply error out.
Oct 02, 2009 | Brother MFC-9440CN Laser Printer
Phillips voip 841 mac driver
i use this phone via a mac. i don't recall any driver being necessary. but check philips website. type 841 into search box and then click software and drivers. link below.
good luck
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=CA&slg=ENG&cat=INTERNET_TELEPHONY_DEVICES_CA&sct=DUAL_PHONES_SU&session=20090612180105_70.79.183.10&grp=PHONES_GR&ctn=VOIP8411B/37&mid=Link_Software&hlt=Link_Software
Mar 24, 2009 | Philips VOIP8411B/37 IP Phone
Philips voip 841: no sound on skype calls, but fixed line works f
We have had this issue recently as well with both our parents and now our own.phone.
Simple solve I found here:
1. Remove batterys
2. unplug base
3. replug in base
4. Put batteries back in
Worked for us - must be a virus or something
Feb 16, 2009 | Philips VOIP8411B/37 IP Phone
Incompatibility with ACER computers?
Hi, I have the same phone, I also have an ACER laptop and running vista home premium.
I needed to download the vista software package from telephonesonline (it costs for the download) but no problems after that it works great.
http://www.telephonesonline.com.au/cordless-wireless/Philips/Skype-321/Windows_VISTA-Download/Setup-user-manuals/call-for-free-philips-voip-321-skype-dect-cordless-dual-pack-phone.html
The only thing with this particular phone is that if you have a monthly account (skype pro) and you use your package as your regular phone you need to add every phone number you call to your contact list.
I haven't found a soloution to dial out from the phone using skype with out it being in the contacts list.
Nov 21, 2008 | Philips DECT VOIP-321 cordless telephone
Use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
Sep 25, 2008 | Philips DECT VOIP-321 cordless telephone
Can not get the voicemail to work no matter what I try
I have skype-in and voice mail too, but don't use either. Instead, I go through www.grandcentral.com, which provides my phone number and voicemail services - forwards calls to whatever phones, cell or skype, that I set it to. I won't run down the list of features, but grandcentral is a great solution to so many telephony problems, and it's FREEEEEE!
Dec 11, 2007 | Philips VOIP8411B/37 IP Phone
Philips VOIP8411 IP Phone Logo
479 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
