Question about Dishwashers
Bosch dishwasher doesn't pump away after replumbing.
Dishwasher won't pump away at end of cycle. I have checked under the impellor and it is clear. I found a thimble shaped back plastic plug in the short rubber hose that connects the drain hose to the under sink trap. I don't know what this is but thought it might be the solution. I removed it and machine still doesn't pump. Grateful for any thoughts on the black plug and on the failure to pump. Many thanks. ian
  • 101 Answers
SOURCE: Dishwasher is full of water
The drain pump needs to be replace.
Posted on Apr 26, 2008
SOURCE: Water not draining from the machine
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Posted on Apr 02, 2009
  • 98 Answers
SOURCE: 4 year old dishwasher no longer draining water
check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Posted on Jul 26, 2009
  • 11 Answers
SOURCE: Bosch dishwasher is not draining all the water at
This is normal with a Bosch. They don't really vent out when they heat, and use a type of evaporation technology to dry the dishes. Best bet is to make sure first that the filter in the bottom is clean, (the little circle thingy on the bottom, turn it a quarter turn and pull it out, run it under cool water till it's clear, then put it back in the same way.) If the water is bothering you or is beginning to make a bit of a smell in there, leave the door cracked a little after you empty the dishes out. unfortunately though, it'll always leave water in the bottom. European technology.
Posted on Sep 06, 2009
57 varieties
  • 1653 Answers
SOURCE: Dishwasher doesn't drain
The drain motor might be worn so it still pumps out fairly well but will let wtare back in once it stops pumping. It may also have something stuck in it so it ot is worth removing and cleaning through with a good degreasing cleaner.
Posted on Sep 10, 2009
Bosch classixx dishwasher starts cycle then says " check water" and then seems to do same thing again and again, pumping water in and draining it again
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left (white plastic disc with two wire connection tag). Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
Mar 09, 2013 | Bosch 24 in. SGS43C12 Classixx...
PUMP BLOCKED OR BROKEN
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SE24A262%2f47&ESHOPTYPE=S
go to link, look at page 4.
you need to remove all internal filters and remove item 165263 (one tx20 screw). this will expose the pump impellor and you should be able to remove any obstruction.
Remember that the d/w will not drain without this cover back on but you can leave it off to check that the impellor turns.
Check also the outlet hoses are clear, particularly under the sink if the d/w is connected directly to the pipes via a spigot rather than on a standpipe.
Good luck.
Jul 04, 2010 | Siemens 24 in. SE20A591 Slim-Line...
My Bosch dishwasher sounds like it is running but does not clean the dishes.
check bottom of dishwasher screens for any blockages or obstruction preventing water from getting into pump. may need a wet vac to **** water out of pump and use a small mirror to inspect pump openings. if no obstruction, the pump impellor maybe broken. replacing the impellor is fairly difficult. the dishwasher has to be pulled from under the counter. repost if you further questions.
Jan 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch diswasher not draining. Cleaned Float, Outlet pipe clear.
you can fix it yourself, but it may involve partial disassembly of the unit.
I have written a guide that will help you. I am working on photos to accompany it, but I think I have made things pretty clear.
It is here. Be sure to tell me what you think!
Jul 17, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water not draining from my bosch dishwasher
there will be something jamming up the drain pump empty the water out of the appliance if you study your operating instructions there will be an intsruction in it as to how to remove the drain pump cover and clear the impellor be carefull ill bet is a piece of glass
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
