Question about Brother XL3750 Mechanical Sewing Machine
Problem with Brother XL-3750
I just purchased this machine and still can't figure out the two stitch dials. The manual is very hard to understand. Can you explain it to me? Also, even though I am using a very light material and the machine is threaded correctly, I still get weird stitches on the underside of the garment. Aaarrrrgh. I'm ready to throw the machine out the window.
  • Brother Master
  • 12,729 Answers
When threading the top thread, ALWAYS RAISE the presser foot. This allows the thread to seat firmly and completely.
Verify the thread path is correct.
For straight stitch, set the stitch pattern selection to 2. Set the stitch length to anywhere between 1 and 4. Leave the stitch width at zero,. This determines how much space there is between each stitch. (Stitch width dial on this stitch selection causes the needle position to move left or right of the center position, so you probably want to just leave it set at the CENTER position.) THE STITCH WIDTH DIAL MOVES THE NEEDLE POSITION--SETTING IT AT 5 MOVES THE NEEDLE TO THE LEFT, SETTING IT AT ZERO MOVES THE NEEDLE TO THE RIGHT. The manual does not say what the setting is for the CENTER position, so logic says 3 is the Center needle position.
For zig-zag, set the pattern to 3, Stitch length anywhere between F and 4. Stitch width set between zero and 5.
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_bb370eus&faqid=faqh00000589_000
Did you not get any training when the machine was purchased? If not, you may want to check with some sewing stores or shops about a beginning sewing class, ie JoAnn's Fabric, etc. May cost a little bit, but the information would be helpful for you. Learn how to properly use the machine instead of throwing it out the window.
In the meantime, this video may be helpful:
https://www.youtube.com/watch?v=UC4ci-t5M60
Posted on Oct 11, 2017
    Habit-Forming:
    New Friend:
  • 6 Answers
Can u chart me on whatsapp +2348189956612 so that i can help.
Posted on Oct 10, 2017
  • 749 Answers
SOURCE: upside down stitching
try adjusting the thread tension control! a loose setting would cause the problem! try increasing tits tightness!
Posted on Nov 02, 2007
  • 69 Answers
SOURCE: Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Posted on Feb 12, 2009
  • 5 Answers
SOURCE: can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Posted on Apr 13, 2009
SOURCE: looping stitches on underside of fabric
Check the bobbin to ensure it is installed correctly. Your bobbin is probably in incorrectly. You shouldn't have to change your tention yet but it is possible. this may sound stupid but the other culprit may be that your forgot to put the foot down. Hope this helps. Let us know. If you found that the tension adjustment did help call your local service center and ask for the in-house tech, ask them where the original # position is when it came from the manufacturer and re-adjust the top tention to that.
Posted on Apr 27, 2009
SOURCE: Brother XL 3030 i can't seem to get it out of the
it is easy to switch the stich modes
there are two wheels on the side on the mchine
one in for manualy stiching *the big one)
and the little one changes the stitch
you have to look at the LCD screen to make sure the numbers correspond
Posted on Jul 21, 2009
How do I use the patterns (marked pattern selection) on front of machine. User manual does not tell how and company does not have any other information on this.
It appears that your machine basically does variations of 2 stitches: straight stitch and zig-zag, plus buttonholes. Take some time to learn your machine by downloading the Workbook (Wkbk) and working through it doing the various stitches on your machine. You will eventually figure out how to combine different selections to achieve the stitches you want. The owner's manual will show you which basic settings will make which stitches.
Instruction Manuals
SINGER 5830C Quick Sales Demo Part 1
Jan 02, 2018 | Sewing Machines
Please explain to me how to adjust the numerical, digital buttons on my 7430 Singer sewing machine?
I just took a look at your user's manual, and boy--you're right, and I've been a computer systems engineer for about 30 years!
Actually, it's easier to figure out by DOING rather than looking at the description on page 35. Basically, selection is divided into two categories--utility, that is, stitches you would use for ordinary sewing, like stretch stitches, zigzag stitches, straight stitch, buttonholes, etc. That is located on the left column, with the arrow keys used for navigation in the middle. The display only shows 5 patterns at a time, so to see all of them, you have to keep pressing the down arrow. Once you have selected the stitch itself, you can then select the stitches width and length, and if it's available for that particular stitch, you can mirror (flip) the stitch, and use a twin needle (if it's available for that design)
The decorative and letter stitches are selected on the right column, and work he same way--they are displayed 5 at a time, etc, and selecting stitch width and length, mirror, and twin needle. However, additionally, you can choose to have the pattern sewn once (the default) or continuously.
I hope that helps!
Sep 21, 2014 | Singer 7430 Sewing Machine
Adjust thread tension
Looking at a pic of this model, there are two dials on it. One near the top, one much closer to the needle. I believe the tension dial is the one that's close to the needle.
I don't quite understand what the problem is with the stitches from your description, but first try the tension dial. Reset it to zero and then try each setting, one by one, to see what happens.
If stitches are still wrong, a few things always to try when there are stitch problems. Clean well around the bobbin case, remove all lint. Do this often anyway, it's not good to let lint build up.
Try a new needle and a new spool of thread. Rethread the machine, a few times if need be. Try a new bobbin too, or wind a new bobbin to try from a new spool.
Try to get a manual for this machine. If Brother no longer has manuals, there are many sites that sell manuals for many machines. A manual can be your best friend when there are problems.
Jul 06, 2014 | Brother LS-2125 Mechanical Sewing Machine
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
Babylock denim pro
I'm not sure what you've actually got, since your question mentions two different machines. Straight stitch is typically the default setting (the thing that comes up automatically) on computerized or electronic machines. On other machines, there may be an indicator for straight stitch (often stitch 0 or 1 if numbered), or it may be a zigzag stitch of width 0, length whatever.
Jan 25, 2014 | White Sewing 1418 Mechanical Sewing...
How to set straight stitch
You can buy a manual for the Simplicity Fashion Pro SW2145 from this link
http://www.sewingandcraftclub.com/index.cfm?fuseaction=product.display&Product_ID=3112&category_id=365&picksku=IBSW2145#top
I would guess from looking at an image of the machine, that you just turn the large dial on the front around to the number for the stitch you want, based on the selection displayed across the front of the machine, blue and red stitches. You may need to switch between blue and red on the selector to get the 2nd range of stitches, probably stretch type where the machine goes forwards and backwards ones, I'd guess.
And vary the stitch width using the dial beside the reversing lever on the lower front.
Oct 25, 2011 | Simplicity Fashion Pro SW2145 Mechanical...
I have a necchi 4595, and well I cannot figure out the straight stitch....the dial doesn't show one?
It's just in the front panel, where the drawing of all the built in stitches are, it's the drawing number eleven from the left, you'll see a zig zag (red) and a straight stitch (black) Select A group of stitches (knob with the arrow) and then select the eleventh stitch (same knob but use the dial, look the manual) and then select zero on your stitch width dial. Hope that helps :)
Apr 23, 2009 | Necchi 4595 Mechanical Sewing Machine
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Proper Settings
A good standard tension setting is usually around 4.5.
If you find it to be looping on the bottom, raise your top tension. If it's pulling bobbing thread to the top, lower your top tension.
For straight stitch, your stitch width should be set to zero, although on some machines (and I believe your Baby Lock to be one of them,) the stitch width setting will change your needle position.
Stitch length is simply a matter of preference.
-R
Aug 14, 2008 | Baby Lock Ellure
Can't select stitches 11-21
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Open Questions:
See all Brother XL3750 Mechanical Sewing Machine Questions
Brother XL3750 Mechanical Sewing Machine Logo
205 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
