Question about KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System
Trackvision repair center in okla
It sounds like gears grinding in when trying to find satelite.
First question, is it under warranty? If the answer is yes go to http://www.kvh.com/WhereToGetService/ and find an authorized repair center.
If not and you feel comfortable with electronics there are a number of things you can check yourself.
*The following is based off my experience with a KVH A7, proceed at your own risk.
Step 1 take the unit off the vehicle and place it upside down on a flat surface, I use a towel to minimize any scratching.
Step 2 take all the screws out from the bottom. There are quite a few and they are all hex heads.
Step 3 once all screws are out of the bottom carefully flip the unit and separate the top from the bottom. Note the 'Dome' does not remove at this point just the plastic around it.
Step 4 remove the 4 large phillips screws holding the 'Dome' on the satellite and remove the 'Dome'
**Disclaimer** you now have access to the electronics of the satellite, be careful! Take ESD precautions and stay grounded to avoid zapping a board.
Step 5 you will notice two electric motors. One that is attached to a large belt under the 'spinning' part that rotates the satellite and the second smaller motor controls the pitch of the satellite.
Step 6 I would start to inspect all parts and see if anything looks broke or out of place. You should be able to move the satellite around in a circular motion by hand without much resistance (there should be some from the engine). If it does not spin I would check the bottom belt and or the bearing track that the satellite spins on.
I would not advise taking the unit apart any farther. Generally most problems I have seen that are not board related are pretty obvious when you get the top off. The KVH family of satellites seem to be the only piece of electronics in the world that there is no good on-line support or discussions for.
Best of luck!
Posted on Dec 24, 2008
There really isn't a great solution to this problem. There are 2 likely causes of the grinding sound: 1) Elevation limit switch bad - this can and will happen with any of these that sees heavy use. 2) Elevation motor failure - slightly less likely than the limit switch but it goes too. Just to clarify the grinding sound - it's not actually grinding, it's the LNB slapping the inside if the housing as the controller its self testing during start-up. You can buy replacement parts for these, but it's been my experience that you should take it to a certified repair center or find someone that is VERY savvy with electronics.
Posted on May 19, 2010
  • Evgeny Chereshnev
    Evgeny Chereshnev Jan 25, 2015
    I think elevation motor can't be the reason of this sounds.
  • 20 Answers
By my experience there may be 2 reasons
1- Elevation limit switch, as described in "mysatpro" answer
2- "Unskrewed" screw, holding FAR plate. (see pic)
Trackvision repair center in okla - trackvision-repair-center-in-okla-0betnbuhgrcovrmdypkzkom3-4-0.jpg
Posted on Jan 25, 2015
1998 Mazda 626 clutch whining/grinding won't shift gears
Need to replace clutch kit will repair clutch problem and throw out bearing
Feb 11, 2014 | 1997 Mazda 626
Gear grinding
Sounds like your Process Drive Assembly has broken its mounting posts and the gears are no longer meshing properly, causing the grinding noise. The drive assy is located on the right side of the machine toward the front. It is held in place with 3 screws. If you wiggle on the gear assy and it moves, then you should go ahead and replace the machine. This is not a do-it-yourself type of repair and should be left to a Xerox Certified Technician if you decide to repair the machine.
Jun 10, 2013 | Xerox Phaser 8550/SDP Color Laser Printer
I have a crib that was manufactured by "OKLA HOMER
And what seems to be the problem ?
Sep 11, 2017 | Baby Gear
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Have lg dishwasher LDF6920ST. Making lound grinding noise under machine,sound like gears grinding.
If the machine works fine other than the grinding sound, there is a blade that is in the center and grinds up residue, somtimes it gets a object in the
space and wont grind it up. If you are ok at taking things apart and puting back together, disasemble the center sprayer, screen and tube to top sprayer, the blade is under the screen housing. clean out and reasemble and should work fine. not hard to do really, when you reasemble do not tighten screws as you intall them as they allign everything, intall then all loose then tighten snug NOT to tight as they go into plastic.
Oct 17, 2009 | LG Dishwashers
My truck stalled out while backing up an inclined driveway. I tried to keep accelerating and nothing happened. I put it in park and the gears grinded badly. I shut the car off, restarted and tried to put...
I've never seen a differential fail in that situation but having been in the business a long time I've learned that all things are possible...Exactly where is the oil leaking on the diff? I'd suggest you get back onto level ground and remove the rear cover on the diff and take a look at the gears. Possible that the spider gears in the center section have broken.
Jul 21, 2009 | 1995 Dodge Dakota
My sons klx 110 grinds when downshifting
While sitting still the gears are not moving. This sounds like a slightly bent shift fork. In the diagram below the slider gear moves left and right to engage the gears. The gear "dogs" fit into holes cast into the stationary gears. The grinding takes place as the fork moves the slider into first gear but the dogs are not getting moved the full distance needed to fully engage the gear because of the bent fork. The center case must be split to gain access to the gears and shift forks.
A “very helpful” rating for this answer? Thanks!
Jun 30, 2009 | 2006 kawasaki KLX 110
Possible transmisson
motr coupling easy to turn??? did you look at closle ( sometimes appears intact, but the center of teh shaft is stripped allowing the motor to "slip" through giving what could amount to a stripped gear sound. the newest motor couplin (285753a) has a meatal sleeve to prevent such a thing from happening
Mar 20, 2009 | Whirlpool Washing Machines
KVH 01 0277 01sl Tracvision A7 Mobile Satellite Tv Antenna System Logo
733 people viewed this question
Top KVH Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a KVH Boating Expert? Answer questions, earn points and help others
