Question about NetGear DG834G Router
Sky branded Netgear DG834GT router
I am with AOL and cannot get this router to connect. I have reset it (inserting a pin in the hole at the bottom) but no luck. I can't find anywhere to put my username and password into it. I think Sky have blocked the router so you Can't use it with any other ISP. I would be obliged if anyone can tell me simply how to get around this.
  • 1 more comment
  • Anonymous May 20, 2008
    can not connect
  • sanniwahab Mar 23, 2009
    I just moved to Tiscali form SKY and I can't get my SKY router to work for Tiscali. I have trying for about 2 weeks now. Reset, use 'admin' and 'password' and '1234' as password severally but no luck. So I need a way out b'cos I cant afford a new router.thanks
  • Anonymous May 02, 2009
    What about if i cant gain accsess to net frommy pc in the first place to do this, as the sky router won`t gain accses to net ?
OK - it can be very simple to do, but took me two hours to work out ;-)
Google for all the info you can.
Download the recovery utility from Netgear.
Download the latest OS from Netgear.
Flash the router with the OS.
Enter the router config panel.
Change the Sky login and password to the ones given you by your ISP.
That should be that.
Keep trying: I did, I'm no expert, and I got there.
Do everything you can to a*sf*ck Murdoch and his company.
Posted on May 16, 2008
Just unlocked my sky router to work with bt.Reflashed firmware and is no longer a sky router.Googled around and found solution follow instructions carefully
Posted on Aug 31, 2007
Reflash the router with the retail netgear firmware this can be downloaded from netgear website at no charge this will restore the router to retial state
Posted on Aug 17, 2007
Try username - admin, password - sky it's sky's standard logon details for their routers. I used it on mine, and hey presto can access all the configuration settings.
Posted on Aug 12, 2007
You are right mate...Sky has disabled the uname n pword n locked the firmware... I really dont think anything will work however u can try finding a work around of how to remove the existing firmware n upgrade a new firmware... That might work
Posted on Jul 02, 2007
Well to set the settings with that router, you must log on to it by www.routerlogin.net then it will bring you into setup and you put your name in to the spaces provided for name and password...
Posted on Apr 03, 2007
    President:
  • 2,961 Answers
You could be right, but normally, as long as you can get into the routers settings by typing it's IP address in your internet browser, you can go through the connection process using the wizard;or go to the connection menu, or new connection and enter your password and username.
No reset button on nsn 1600 modem
There is a reset button the modem iteself.
You can check for a small hole on the bottom side of the modem, under it is the reset button usually.
So, when the modem is turned on, then you can use a pin and insert it in the hole and try to hold it for at least 30 seconds.
After that release it and your modem will be reset.
After doing this resetting, you will again have to configure your router for internet connection.
Mar 04, 2014 | NetGear WGR614 Wireless Router
HOW DO YOU CONNECT A BLACKBERRY PLAYBOOK TOA NETGEAR DG834GT ROUTER?
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 15, 2012 | Computers & Internet
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Does the netgear dg834g work with sky broadband
Thats an ADSL modem/router, so would be used via the telephone line In fact this is the standard router often supplied by SKY DG834GT
theres a number of answers here on the sky site for setting up a router http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=25126ec2-287b-4e70-9014-967423a8dbf1
sky users tutorial for setting up a router http://www.skyuser.co.uk/forum/view-router.html
Mar 19, 2010 | NetGear DG834G Router
I can not remember my username and password
You can factory reset the router using the small button on the back, hold it in for 30 seconds with the power on to the router. This will clear all settings from the router including the password, so you will need to set up the router again after the reset.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 08, 2010 | NetGear WGR614 Wireless Router
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Netgear ADSL super G wireless router
I hope this will help you to solve the problem...
http://www.jjclements.co.uk/index.php/2007/09/30/sky-router-dg834gt-unlock/
Apr 27, 2008 | Computers & Internet
NetGear DG834GT
Are you sure you are entereing the correct passphrase, or is it a network key (usually entered in Hexadecimal). Is your Netgear router set up to use WEP or WPA or equivalient security?
Have a look at this thread. That may offer some insight.
http://discussions.apple.com/thread.jspa?messageID=6168599
Mike
Jan 05, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
8,732 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
