Question about Whirlpool Refrigerators
Upper freezer is squeling
Its coming from the very back part of the freezer sometimes stops and then starts again
    Problem Solver:
  • 6 Answers
The most likely cause of the squealing is the eveporator fan motor. It may continue for quit a while before it finally quits. When it stops completely the evaporator coil will freeze solid and there will be no air blowing from vents to refrigerator.
Posted on Dec 20, 2008
Hyundai accent 2007 belts are squeling upon startup. After 15 minutes they stop squeling?
Over time, belts get a glazing, slicker, or will stretch out some. Sometimes you need to replace the tensioner arm.
Since it typically is cheaper and quicker to replace the belt(s), I would do that first. If that doesn't fix the issue... the next potential problem would be the tensioner arm or pulley.
Semper Fi,
Z
Feb 15, 2018 | Hyundai Accent Cars & Trucks
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Hi I have a Maytag fridge freezer GC2227CDFB The fridge compartment has stopped working, the lights still come on when door open, the motor seems to be working, when temp. setting is turned down to 0 the...
Your problems are exactally the same as mine. I have taken the freezer back panels off and fornd the elements blocked with ice, the upper and lower channels to the fridge are blocked with ice and obviously therefore no0 cold air is going the fridge, I have de-frosted the freezer and put back together and everything works great for 2 weeks when the same thing accurs. My settings for both fridge and freezer are on the lowest possible, but the wife does fill the freezer with too much food! I guess I need an expert in!!
Jun 16, 2010 | Admiral 26 cu. ft. Side-By-Side...
Why does my 98 honda crv stall when coming down a hill?
when I make a sharp right turn with my 98 honda crv, I get a "squel' from the back right tire. I also sometimes get a squel that something is slipping when I accelerate from a stop light
Dec 01, 2009 | 1998 Honda CR-V
MY GE PROFILE REFRIGERATOR IS WARM, FREEZER IS FINE.
First we need to find the defrost timer located inside the fresh food compartment and behind the control panel. Sometimes there is a small hole covered by a plastic plug to hide the opening. remove the plug and with a flathead screwdriver turn slowly clockwise until the compressor stops. This should put the refrigerator into defrost. After about 25 minutes the timer should turn the refrigerator back on,if not turn again slowly until the compressor comes on again. If this is happens we need to replace the defrost timer part number 660573 Let me know what you find, Thanks, Sea Breeze
Jul 26, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Making a loud noise
yes. is the fan hitting ice. the fan activates when close the door the upper baskett press the fan and light switch............... good luck.......... LEAVE YOU COMENT IF IT WAS GOOD FOR YOU
May 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
