Question about Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Cleaning a furnace humidifier steel filter?
I have a honeywell furnace humidifier. Just check it and the filter is really ditry clogged. How to i clean this?
  • IBjohn Jan 02, 2009
    Ditto, I just bought a house with a General 1042-L Power Humidifier. It has an upright metal filter that the water flows over. I would like to clean up the mineral deposits and make sure the unit is in proper working order before I cause a problem... I don't know when it was last used but the house has been vacant for 3 years. Any general info would be greatly appreciated.
  • Stephen Evans May 11, 2010
    Is this a humidifer with a float and pan or does the water just flow through it? Steve
  • 61 Answers
Most water panels are generally replaced once a year on flow through humidifiers.
Posted on Jan 02, 2009
How to remove calcium from metal humidifier filters
Flush it with diluted C.L.R. and water solution, about 1 to 1, then rinse and flush with clean water for several mins. Thank you
Jan 02, 2011 | Honeywell Power Humidifier: Furnace...
Honeywell 22a worked fine last year this year will not turn on.
Check solenoid 24V. You should here a "click" when you turn on the unit when furnace is running. These things clog up with chemicals.
Dec 12, 2010 | Honeywell HE220A1019 Whole House...
No Water Flow to Honeywell Enviracaire HE225A1006 Humidifier
I have same problem with no water flow on identical humidifier but was able to fix it. Removed the inlet to the solenoid valve and found (1) a small taper mesh filter inside (2) a small diameter orifice that was clogged. Cleaned the miniature filter and used a sewing needle to open the orifice and now works perfectly.
Jan 09, 2010 | Honeywell Humidifiers
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
Mod#BLU100K948A The 2 selenoids on top of gas valve click when they open (normal). Sometimes they work fine, sometimes they have a rapid clicking noise and do not open the gas valves. Furnace just runs and...
The first thing to check would be the filters in the house to make sure they are clean, then check for any blockage. One easy way of seeing if the airflow is good, just put your hands in front of a vent and see how its blowing. Your furnace has what you would call sensors, and if they sense the air flow is inaccurate or to hot inside the unit, the unit will run, but not light. Also, if it tries to relight to many times, the furnace will go into lock out and you have to manually reset it by cutting the power to the furnace. Its kinda hard to diagnose these sometimes over the pc, but I hope it helps.
Nov 02, 2009 | Honeywell Power Humidifier: Furnace...
My honeywell humidifier attachment on my furnace will not start after the summer with water running to it.I have the humidity cranked up, but the filter is still bone dry.
Humidifiers usually are wired up to ONLY come on when the Heat is on and the fan running....anyother time you check it it will not be powered or wet...turn your heat on , wait till the fan comes on...then turn up your humidistat you should hear a click if its a flow through type and water should start flowing from the top...or if its tyhe drum style with the sponge...you should see it then turning...if it doesnt turn the pad/spindle may not be installed properly...if only fits one way
Oct 24, 2009 | Honeywell Power Humidifier: Furnace...
I HAVE A HONEYWELL CHRONOTHERM 3, THE DISPLAY SHOWS THE TIME & -AC. I THINK THE UNIT IS FIRED. PLEASE ADVISE.
you have no power to the thermostat check to see if the furnace switch is on or if the blower cover is on properly.
Oct 17, 2009 | Honeywell Power Humidifier: Furnace...
Cant find old furnace filter for model # fguj080abn
The furnace model is irrelevant. The important question is usually the dimensions of the opening for the filters. The most common sizes are 16"x25"x1", 20"x25"x1", 16x25x5, etcetera. There are exceptions such as specialty filters like electronic ones. I suggest using inexpensive pleated filters but you could just use filters that you cut to fit instead. Have a helpful gasfitter assist you if necessary.
Dec 08, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Humidifiers Logo
2,394 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Bill Long
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
