Question about Tascam FW-1884 Firewire Audio / Midi Interface Sound Card
How do i reset my fw 1082
All my lights stay on
  • baolocpham Apr 03, 2009
    my fw1082 all light freeze!!!!! anybody can fix this??
I have the same problem. To reset you have to hold down the first row (horizontally) and third row of buttons on the upper left side (6 buttons in all) and power on the machine. The lights should all flash and come back on.
This reset does not however fix the problem that all the lights remain on. Has anyone found a fix to this? I've read that this is caused by a "burnt" out firewire card (due to the flaw in design that the card in the system draws too much power from the computer).
I've also read that the card is somewhere between $150 and $300...
My advices to anyone getting this thing... get as long a warranty as possible, because it will probably break after 4-5 years of light to moderate use.
Posted on Jan 20, 2010
Latency Problms
You'll never get rid of the latency problem if you record from a speaker. Speakers are analog and when you mix digital with analog you get latency.
May 10, 2017 | Tascam FW-1082 Audio/MIDI Interface and...
How do I hook up my tascam fw1082 to a mixing board?
Hi, There are two ways you can connect it up. You have a TRS (Tip Ring Sleeve) monitor output that could be patched into the inputs of any analog mixer, balanced high level inputs.
You also have a S/PDIF stereo out. If a digital mixer doesn't accept S/PDIF you can get a converter to change S/PDIF to an AES, which any pro digital mixer will work with. I think HOSA has one for about $60.00, you might find something on Ebay as well.
Here is a Link to the TASCAM Spec page for you FW-1082
http://tascam.com/product/fw-1082/specifications/
I hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Tascam Audio Players & Recorders
Подскажите,...
Regular reset: go into the menu and find "reset"...follow the on-screen instructions. Manual reset: remove the card and batteries...press every button...leave it alone for 20 minutes...insert the card and then the batteries...turn it on. You mentioned damaged firmware. Do you mean you attempted a firmware download and something went wrong?
Aug 17, 2010 | Olympus FE-330 Digital Camera
How do you reset an HP R727 camera?It comes up saying it has experienced an error 5555AAAA-61EE-14B-031 as soon as you switch it in. Battery is fully charged.
Normaly the repair service reset camera by using special file on the SD card.This file is impossible to find it on the internet.But you can try to update FW maybe it will help to this error message.You can try download lates FW for R727 from google.(Last FW version is 3.02.15).
Then extract exe file and copy FW file to the SD card.Put SD card into the camera and close battery door.Hold Shutter button and power on camera.After FW update is complete just power off camera.Then try it again to swith on.If it will not help the only way is send camera into the repair service.
Best Regards
AIOS
Apr 17, 2010 | HP Photosmart R727 Digital Camera
I have the dreaded all lights on on my Tascam fw1082
I would vote for a power supply issue on this one.
Jan 26, 2010 | Tascam Music
Error 0X5b
Такая же фигня. Фотал нормально. Отключил автофокус, потому что фотал летящих птиц. Две фотки сделал и на третьей выскочила ошибка Camera errop code 0x58 . Выключение и вытаскивание аккумулятора не помогло. Вкл/выкл. автофокуса тоже. Не знаю, что делать. Завтра понесу в сервисный центр сдавать. :( Грустно.
Aug 08, 2008 | Sony Alpha DSLR-A100 Digital Camera
Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Jun 04, 2008 | Ricoh Aficio SP C811DN Laser Printer
Tascam FW-1884 Firewire Audio / Midi Interface Sound Card Logo
3,935 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
