HP Color Laserjet won't print from desktop - or wirelesslly from laptop - but WILL print directly from laptop.  : ( Need knowledgable networking and driver and  port personn to walk me through this.
  • 1 more comment
  • Anonymous Dec 20, 2008
    I don't know = I assume it is internal because it is just a computer - not other boxes, etc. ..
  • Christian Goforth
    Christian Goforth May 11, 2010
    Are you trying to share the printer out when it is attached to a computer or do you have it connected to a router with a network cable?
  • Christian Goforth
    Are you using an external print server or is it internal?
  • 30 Answers
I am going to assume that the printer is plugged directly into the desktop and if so then you need to go to printer and setting and setup you color laserjet as a shared printer. Now see if you can see the printer on your network, thru the wireless connection on the laptop.
once done that will probbably work, but you are probbably going to need your desktop on to print
Posted on Jan 05, 2010
How to add NIC in HP color laserjet CP1215 Printer?
If this model HP does not have an expansion slot for a HP Jetdirect Print server, then to use this printer on your network you have two options.
1. Connect the printer to a desktop computer on your network and set it uo as a shared printer. This means this computer and printer needs to be powered up for the other computer on your network to print to the shared printer.
2. Connect the printer to a print server that is connected to your network.
Nov 24, 2010 | HP LaserJet P2015 Printer
Network printer problem
try the usb cable if the computer can print print test that would be the network is wrong ip address that declare you on printer
Feb 04, 2010 | HP Color LaserJet 2600n Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
Hp color laserjet 2600 megnta not printing
thanks alot u solutions.iam very happy for giving me this knowledge.faisal
Aug 17, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Jan 27, 2008 | HP Color LaserJet 3500 Printer
Computers & Internet Logo
55 people viewed this question
Alun Cox
David Payne
David Payne
