Most printers come with a cd that you have to put on your computer. The cd's have to drivers on. If you don't have the printer cd any longer, maybe contact the manufacturer or any electrical store, they may be able to order one for you.
Try to check the Print Spooler Service on your computer and make sure that the service is running. On your computer, go to Start menu > go to Run to Start Search and type Services.msc. In the Services window, scroll through the items and look for Print Spooler. Right-click on Print Spooler > select Start. Click on the OK button to save the setting. Then try to run the installer again to verify that the installation will go through now.
1.Errorinstalldriverprocess How toinstallthe correctdriver canon -Do not connectthe printerto thecomputer.So, turn on theprinterbut do notconnect the printerto thecomputer. -Insert thedriver CDand do theinstallprocess. -At the time ofthe install process, it wouldappearthe requestconnect the printerto the computer. -Connect theprinterto thecomputer.The computer willdetect the printer,andinstallprocesswillcontinue untilcompleted. -Then,press theSTART-Printersand Faxes-Rightclickthe CanonMP258seriesPrinter-select Printingpreferences-clickMaintenance-Printheadalignment-Alignprint head-OK-etc.Performprint headalignmentuntilcompletion(approximately 3timestheheatprintalignment).Print headalignment,to configuretheprinterand computer. -After theprint headalignmentis completed,the printer is readyto use.
Installthe wrongdriver canon -Connect the printerto thecomputer,then performinstallprocess. -Solution:disconnectthe USBcablefrom the printerto the computer,thenuninstallthe drivers andapplications that arealreadyinstalled,then restartthe computer. -Repeat theprocessto installin the correct way.
2. Drivers don't support the operating system If you need a Canon MP258 driver download here: Canon Support and Download
- Follow the link - Product category = Inkjet Multifunctional Printers - Product series = PIXMA - Model = PIXMA MP258 - Document type = Drivers & Software - Click Find - Select OS = example : Windows 7 - Download driver printer; MP250 series MP Driver Ver.1.04 - Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
May you remove or uninstall by mistake that's way is not showing now don't install again to follow the mention below instruction.
1) Plug on you USB cable to PC and power on the printer.
2) Put the Lexmark printer software installation CD in you computer CD-Rom.
3) Open the CD-Rom, and duble click the setup exe.
4) The setup will take few minute to install the driver.
5) After installing the driver reboot your computer. and start to printing
Any drivers you need can be found on the lexmark website. Note that some printers need the software installed before hooking up the printer. I'd try to install the printer first. The software will tell you if the printer needs to be connected.
In order for your printer to work, you need a Software Installation CD (If you don't have it, you can found it on internet as a "driver" or "software"). For your model, click HERE , download this driver and then install it.
there will be lot of possibilities .just follow all these steps. first you make sure your printer is working fine just remove the test print form going to printer and faxes option just right click on it and give test print if it is print that means your application have some problem from where you removing print out if test page is not coming then you need to reinstall the drive of printer. kindly uninstall the printer driver andsoftware restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt youfor connect the usb cable then connect it and follow the instruction. It will resolve your problem. kindly uninstall the printer driver andsoftware restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt youfor connect the usb cable then connect it and follow the instruction. It will resolve your problem In run window type services.msc and the go to print spooler option just stop and restart the service. and also switch off and switch on the printer and try to cancel all the documents form print spooler it will remove all pending jobs. Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd
tol tingnan mo sa control panel ung sound and audio devices. makikita mo dun ung volume tapos pag di mo magalaw ung volume bar. it means that your audio device was disable.tingnan mo rin sa taskbar sa right katabi ng oras ung icon ng audio. kung wala un ibig sabihin wala kang audio. tingnan mo rin kung meron kang sound effect manager or other because that is the software of the audio or kung anong meron ka. kung wala kang ganun it means that you dont have any audio driver installed.
kapag wala pa rin try to reinstall again the audio driver camed with your motherboard's cd. i hope na maging ok na yan tol. ask ka ulit kung meron pang problema.
You need to reinstall your printer driver. If you have the installation cd,
1. unplug your printer from the computer,
2. install the driver from the cd,
3. plug your printer back into the computer
4. turn the printer on
5. print your document.
If you do not have the installation cd, try the printer manufacturer's web site for the print driver. Before installing the driver, disconnect the printer from the pc to make sure installation goes smoothly.
Once the driver is installed, when you plug the printer into the computer and power it on, the computer will find it and finish the installation process automatically.
This will not help the problem posted by guest. His problem is totally unrelated.
