Question about Maytag Neptune MAH5500B Front Load Washer
Kent how do I install a door lock assy. on a maytag MAH3000AWW washer
  • jrfbigman May 11, 2010
    once u remove do u replace the whole piece or do u replace each item in the unit
  • 179 Answers
Take the four screws out of the dispenser on top of the machine. take the door and front panel off the machine on both sides there is a 5/16 bolt that holds the lid down take them out lift the lid now you can see the lock mach
Posted on Dec 20, 2008
Maytag Neptune washer serial #MAH3000AWW that the water won't quit filling and is also hot water regardless of temperature selection and door lock doesn't always go on. What would cause this?
Sounds like hot solenoid is stuck open. Replace water valve. Door lock problem would either be defective lock, the control, or wiring between the two
Oct 08, 2018 | Maytag Washing Machines
Model MAH3000AWW won't spin
As giving info it seems it needs new control board and door lock .as I could see this is very old model and parts are very expensive
May 06, 2014 | Maytag Neptune Washer Door Mah3000aww
Maytag neptune mah3000aww washer. It cycles then sits at the end of spin, does not go off. then the door will not unlock. I turn to off, push off button. it is anyones guess if it opens
Possible that the door lock is not actuated to open after the end of the cycle and could be jammed. try using a degreasing spray like WD 40 and if there is any issue with the lock.
check this link: door lock
Jul 05, 2012 | Maytag Washing Machines
My maytag neptune MAH3000aww washing won't go into
most common issue with these is the door lock assy. You need to remove the control panel and check the R11 resistor on the board most likely it will be burnt. This was a common issue a few years back. If the R11 resistor is burnt you need to replace the door lock AND control board or your problem will occur again.
Hope this helps _MJ_
Jan 31, 2010 | Maytag Washing Machines
DOOR HARD TO CLOSE
need your door lock assy replaced
Mar 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer MAH3000AWW
order the wax motor kit and replace parts from the internet. there are plenty of videos how to do this. it does require minor soldering and a little mechanical aptittude.
Dec 30, 2008 | Maytag Neptune Washer
My washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the "ON" led just light up 3-5 sec then turn off
my washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the led just light up 3-5 sec then turn off
Aug 21, 2008 | Maytag Neptune Washer
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Jan 18, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
