Question about Logitech ClickSmart 420 Digital Camera
Dropped my 420
I need to know where i can take my 420 Click Smart for repairs or where to send it I dropped it in my Driveway aand now the pectures have a redish orange rainbow color to them and also blurry . If I shake the camera ,I can hear something loose inside............I live close to Winnipeg Manitoba, Canada..If Anyone can advise me where to go I would greatly appreciate it as no one here seems to know what to do!!! help please ......My camera is like my best friend!!!!!
  • mhollister Dec 08, 2008
    I also dropped the camera and now all the pictures are blue. Is this fixable?
Download software for Logitech click smart 420
Posted on Sep 20, 2007
I need help with 2004 freestar headlights no highbeams and one dim i checked relays under hood, and replaced the multifunction switch. what next
I would suggest you take it to a qualified repair shop if you don't know how to test automotive electrical circuits > Viewing wiring diagrams to see what all is involved , using a DVOM - digital volt ohm meter etc.... Just replacing parts isn't the proper way to do it.Looking at a wiring diagram i see the multifunction switch. is a low voltage input to the smart junction box ( computer) The smart junction box supply's B+ voltage for the low beams . For high beams the SJB energizes the high beam relay . With the smart junction box being in control there could possibly be diagnostic trouble codes stored . Autozone an advance etc.. can not pull these codes . One dim one ???? One dim low beam ? Could be a ground issue . You probably don't know about voltage drop testing ,do you ?
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Electric Testing Techniques You Need to Know
Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info. Year ,make , model an engine size . Under system click on lighting ,then under subsystem click on head lamps . Click the search button then the blue links . Test don't guess
Mar 17, 2018 | Cars & Trucks
My 21" sharp tv aphprody the pecture black & white
Check the input menu and color settings.
Feb 01, 2013 | Televison & Video
Desktop out for repairs. Moved 420 label printer to laptop area. Have copy of label file from desktop. Can't get the labels into the laptop printer and it's not in FAQ that I can find. Really need to make...
Microsft Word is probably not only the best but if not the only solution. Test print a label or two, at a time and then a sheet, at a time. Attempting to print muliple sheets from a file associated with a different, standard, printer may not line up well enough to print pages and pages, unattended.
What you see between these ---> < - > <---- Brackets are actions for you to perform.
You'll may wish to choose a Microsft Word Template, you can do that by opening Microsoft Word, <Help>, <Tempates> or (if you cannot find templates) via: http://office.microsoft.com/en-us/templates/ select a label from your file and pick the number from the list that corresponds with the label on the box of labels. Please forgive the ambiguity, I'm working blind without knowing your Operating System or your version of Word, what printer, etc... This is general enough for most systems.
Here's the order:
  1. Click <Tools>, <Letters and Mailings>, Click <Envelopes and Labels>.
  2. Click the <Labels> tab, and Click <Options>.
  3. First choose the printer you want to use and next the label supplier number from the box sheets that you'll print your labels on.
  4. Click <Product Number>, scroll to the corresponding number from the label box. click Ok
  5. Click <Envelopes and Labels>, Click <New Document> and a label document will open.
  6. Type data onto the labels you choose to use, Avery number work well with Word .
  7. Click <File>, Click <Print>.
Now, you could try to make a copy of your label list, to experiment with, but it's probably best that you re-type the labels into each of the boxes while reading from your label program; until your PC is returned
Mar 11, 2011 | Seiko Instruments Smart Label Printer 420...
Need the output feed roller gear for the zebra ql 420 printer
Zebra doesn't sell parts for the mobile printers. You will need to send it to Zebra repair.
Jun 30, 2009 | Zebra QL 420 Thermal Label Printer
Oil Leaking slightly from engine block
Could be some thing as simple as a leaking filter, drain plug, or oil pressure sending unit. If it hasn't been in for an oil change lately, take it in, mention you have seen drops on the driveway, the tech will likely note the leak and possible solution. From this you can determine the cause and cost.
Apr 14, 2009 | 2000 Nissan Sentra
I need program to instal my ClickSmart 420(logitech )
sir,you should install the user cd along with the cam,when you buy it.Or try to dawnload in logitech website.
Jan 20, 2009 | Logitech ClickSmart 420 Digital Camera
I have a logitech click smart 420, my commputer is microsoft vista, the camera won't down load
I Have The Logitech ClickSmart 310 And Came Across The Same Problem.Here Is What I Did;
I Installed Drivers For Logitech Quick Cam v11.7 It Works Fine.No Audio Im Not Sure If This Will Work On The 420 But Is Worth A Shot Huh?
May 03, 2008 | Logitech Cameras
HARD DISK SMART IS BAD
Go to My Computer.
Right click on your hard drive and select Properties.
Select Tools.
Click "Check Now" to run check disk. If it finds any problems it will fix them.
Apr 10, 2008 | Toshiba Satellite A105 Notebook
Click smart 420 and 510
yes.you need to take of the software and reinstall the 420 software.make sure you install the software befor using the hard ware.best of luck.mark
Jan 21, 2008 | Cameras
Logitech ClickSmart 420 Digital Camera Logo
114 people viewed this question
Top Logitech Cameras Experts
Are you a Logitech Camera Expert? Answer questions, earn points and help others
