Question about LG 42LC2D 42 in. LCD HDTV
Plasma tv screen going black
I have a 42" LG plasma tv the screen is starting to go black from the right hand top corner and spreading downwards
    Problem Solver:
  • 6 Answers
Pls contact 9420806154 for solution
Posted on Dec 21, 2008
How to fix blank spots on the screen that get worse when you touch the screen?
do you still have a complete picture ?,are the lines coloured,?
do the lines go from left to right or do they spread out from the blank spot in a circular direction like the suns rays?
from your description above i am sure you are describing a broken lcd screen,if i am right there is no repair feasible for this set..
Len
Aug 31, 2014 | LG 42PC3RA 42 in. HD-Ready Plasma TV
LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Mar 05, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Tv only has top right corner showing picture
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
Mar 24, 2009 | Akai PDP42Z5TA 42 in. Plasma Television
Little transparent box with 2 in top right hand corner of screen
Sounds like a possible "burn in" issue. Although rare, seems like a rash of these are happening to the same model.
Jan 08, 2009 | LG 42LG50 42 in. LCD HDTV
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
Maxent 27" LCD Flat Screen TV
This is a fault i have seen with phillips lcd tv's and i suspect it could be the lcd screen itself,the ribbon cables from the screen are heat contacted on to a circuit board and there could be anything from 10 to 15 of these ribon cables and over a period of time the heat generated from the internal panels will deteriorate the plastic ribbon cables.
Try twisting the screen gently by placing your left hand on the top left hand corner and your right hand on the top right hand corner and gently twisting,if the lines go and then come back after you let go then a new screen will be required but it may be cheaper to buy a new one,could be worth buying the extended warrenty.
Feb 02, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
LG 42LC2D 42 in. LCD HDTV Logo
176 people viewed this question
Computer Repairing
Computer Repairing
