Question about Fujitsu Siemens AMILO Pro V2010 Notebook
My laptop isn't turning on anymore ! Although its battery is full
I tried to switch it on without the battery, using the charger only and it did't turn on too ! dunno what's the problem with it. Please give me your advice
  • retxet May 11, 2010
    Do any lights come on at all when you try switching the laptop on with the charger? If so then you're in luck. If not then try this trick anyways.
    Unplug all the power from the laptop (battery and charger). Now hold the power button in for 30 long seconds. Then try plugging it back up and powering it up.
    If that trick works then hoorah! If not then you may be in store for a hardware problem. Try smelling close to the fans to see if there is a burning smell.
  • 56 Answers
The fujitsu laptops from that time i'm known with have a little display thing in the middle just over the keyboard, but that doesent have to say anything try clicking on the power button lots and lots of times if it doesent turn on then and just the fan start for a little moment you may have a mother board that has gone bad but if you take of the keyboard and stuff from it and under there somwhere you will se a copper thingy that goes to you mother boad where it is some screws, try and take those screws out and start the laptop then it shold start then while its still on screw the cooler on to the mounting but nott hard , i've had the same problem with a fujitsu siemens e4010
Posted on Jan 02, 2009
Tablet wont charge
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Apr 01, 2014 | Samsung Tablets & eReaders
Our one year old ZS3 calims all of a sudden "No battrey power remains", even that the battery has been freshly charged. The charger and the Voltmeter show a full battery. So where to start ? a...
Hi, My best guess would be that the battery isn't actually holding a charge anymore. I'd suggest trying a different battery as that should solve the issue.
Jul 21, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
Screen does not light up - stays black
remove charger,
remove battery
press and hold the power on button for 1min
place battery
press power on button,
if it doesnt light up, then check your memories chips. try another one
good luck
Jun 19, 2011 | Sony VAIO Notebook
My friends Toshiba Satellite A105-S2719 dropped to the floor while it was connected to the changer. In noticed the charger was damaged so i used mine it will not turn on Motherboard maybe. i replaced...
When using other charger for a laptop, you should mention CAREFULLY the volt and ampere for the new charger.
But first, if you have other laptop similar, you can use it's battery to test the dropped one.
Please tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite A105-S2719 PC Notebook
I have hp 530 laptop.i used a cleaning paste that sipped into the keyboard and now its not working with the touch mouse although the laptop is working.please assist
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | Computers & Internet
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Jan 06, 2011 | Dell Inspiron 1545 Notebook
G3 Doesn't power up
I,d check that the laptop isn,t in Standby or powersave Mode.
Check the Ram, and re-seat if necessary.
Try the laptop without The Battery.
Regards Mike @ compurepair.
May 10, 2008 | Apple iBook G3 Mac Notebook
Amilo pro v7010 laptop wont switch on
If so, unplug it from the wall charger, remove the battery and wait 5 minutes. Then plug the unit back in, leaving the battery out. Attempt to power up. You may lose what work you hadn't saved from the previous use, but nothing else.
If that doesn't work, it's possible that
A) power socket isn't completely connected to the motherboard anymore, so
B) battery isn't charging properly, or
C) the wall charger has gone bad.
I'd say you're in hibernation tho.
Good luck
Nov 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
306 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
