Question about Sony Playstation 3 (PS3) Console
PS3 starts up but doesn't show up on the screen.
This is the first time that this has happened. I've had my PS3 for over 2 years now and it has always worked fine. But for some reason, I turned on my PS3 normally, with all the correct plugs in, but it has a connection problem through the cable, so it doesn't show up. My TV is a HD one and I have used the HD cable before and it worked.
I also tried using the old cable to see the screen, but it doesn't work either.
Please help!
  • mpahnke Dec 20, 2008
    Same thing for me. Any fixes?
  • Anonymous Jan 03, 2009
    i have tryed holding it down but nothing happened it just stays black nothing show up?
    Sergeant:
  • 319 Answers
You can try resetting the video. I had one that went out on me like that, and Sony told me to hold down the power button till you hear 2 beeps this will reset the video settings.
I never did get the playstation3 fixed so I tore it apart and learned what makes it tick. Very interesting.
Posted on Dec 20, 2008
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
Apr 19, 2012 | Sony Playstation 3 (PS3) Console
The wireless controller takes to much time to connect the ps3, i try with other controller and still the same, and i cant get to the net.
Seems like you might have an EFI (Elecromagnetic Interference) problem. Has this always happened or is it just starting to happen?
################## JUST STARTING
Have you entered any new electrical equipment to the area? If so, try removing that equipment and check to see if it works. If It does, you just simply can't have that device near the PS3. If it doesn't work still, try contacting sony via 1-800-345-7669 ##################
################## ALWAYS HAPPENED
You have a defective PS3 and should return it before the warranty runs out. ##################
Jul 17, 2011 | Sony Playstation 3 (PS3) Console
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
I turn my PS3 on and the screen is always blank. I tried holding the power button for 5 seconds as per the manual and this doesn't help, nothing happens. I also tried entering a safe mode but I can't as I...
I recommend you try to access Safe Mode again.
The way I understand it, your ps3 is supposed to turn off after the third beep as you keep holding the Power button. Then you start the sequence again, and this time you will get the double beep.
Of course, Safe mode is only available for PS3's with system software of 2.60 and higher, perhaps yours is older than that?
I hope that helps.
____________________________________
Sony PS3 Safe Mode
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Ughhh, I see that others are having the same problems with their PS3. I bought a PS3 for my two sons 2 years ago for $400. It won`t play cds, or movies. The little bubble or icon comes up on the screen,...
take apart the ps3 and clean the laser lens with a que tip if this doesnt fix it you may need a new blu-ray drive that you can ussually find on ebay for $50 ish, just make sure when swapping it your carefull with the logic board attached to your current blu-ray drive as you have to use this with the new drive because ps3 locks each logic board to each ps3.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
47 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
