Question about Sanyo DVW-7100A DVD Player/VCR
Dvd player The vcr works great.But the dvd player gives only sound and no picture.Worked well for about a year.Hardly used though.How do I fix this?
  • Jon Jalowiec Apr 19, 2007
    have used all types of available connections.same problem.
  • gmalisa Apr 25, 2008
    Worked fine for a couple of years, but now dvd player makes odd noise or stops the movie & doesn't want to release it, etc.
    I tried a laser lens cleaner disk - but it didn't help.
Holding the PLAY button for 10 seconds worked for me. It turns off "PROGRESSIVE" scan mode, which is incompatible with the coaxial cable output.There was no button on the remote to do it, so I had to find this page to tell me how to reset.
Posted on Jul 06, 2008
Advice worked in about 10 seconds, Thank you
Posted on Mar 11, 2008
I had one do the same thing and just tried and that fixed thanks aloooooot
Posted on Feb 24, 2008
Turn on power-set to dvd. If sound only (no picture)hold in on the play button till it resets. Takes about 30 seconds.
Posted on Sep 14, 2007
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
If you are useing RCA connecter change to a coax connection. In otherwords change to another connection type. The combo dvd/vcr units are not built very well.
Posted on Apr 18, 2007
SOURCE:
There is no sound on my Sony SLV-D350P DVD Player / VCR Combo. The only section that works great is the VCR, but the DVD player sound just went out for some reason. I've changed the RCA cables, and...
Hi, As long as you have the picture it means that DVD's Laser Eye is Ok.. Pls Check your connections to make sure the audio and video cables of both VCR and DVD are properly hooked up to the television. Color coded cables should be matched with the jacks of equal color. Yellow corresponds to video while red and white are both audio.
Ensure the DVD is in standby mode if you are not getting picture from the VCR. The DVD cannot be running at the same time as the VCR is playing when you want to see the VCR picture.
Connections with combo units are often inconvenient, forcing you to use separate video hookups for each section (DVD, VCR), a problem for older TVs. This player has it figured out: a single RF or composite-video connection to a television will display either the DVD or the VCR signal, depending on which format you're viewing. If you want to view DVDs in S-video or in component-video (either interlaced or progressive-scan), you will need to use two inputs. though: any component- or S-video-equipped TV will offer sufficient inputs for both of the SLV-D350P's formats.
It's a different arrangement for audio: you can listen through a single set of stereo analog-audio cables for each component or--if you want to enjoy DVDs in discrete 5.1-channel surround sound--you can send the DVD's audio to a compatible audio/video receiver and a multichannel speaker system through a digital-audio interconnect (either optical or coaxial,). The unit also comes with an RF cable that will transmit DVD/VHS audio and video to your TV.
In conclusion,for a best tech solution I prpose you to connect DVD audio directly to your Stereo and listen as separate audio source.while Video goes to TV as usual. Hope this helps! if you need more help pls contact me..Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 02, 2011 | Sony SLV-D350P DVD Player/VCR
We are unable to get video (picture) on our TV, when we hook up to our new DVD/VCR combo. The combo doesn't have an S-video port and our TV does. We get perfect sound though.
Your TV should also have a regular composite video input jack (yellow) in addition to the s-video input. Use that input instead of the s-video. The video won't be quite as clear as with s-video, but you have to work with what the combo gives you.
Apr 22, 2009 | Zenith C27A24T 27" TV
No tv picture
my less than 2 yrs. old hardly used Samsung plasma is turning off automatically for no reason within 10m minutes of watching. What could be the problem??????????
Mar 16, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Dec 23, 2008 | GoVideo Go Video DVD/VCR Combo
I have connected my DVD/VCR to my Samsung 32 inc television but I get no sound
I had a strange issue yesterday too.
Our Samsung DVD/VCr all in one combo did a similar thing.
I used the HDMI cable for the DVD into the TV input labeled HDMI/DVD. That worked okay.
But the VCR part didn't work.
At one point I got sound but no picture. Using the RCA cables in the back on another input "Component 1"
I was trying to squeeze the best picture out of the player using the S-VHS cable.
I thought it did picture only, but the Plasma seems to be more picky about input sources.
I got everything to work keeping the DVD as a separate HDMI to Plasma TV feed.
The VCR was 3 RCA's Yellow (picture) red and white for stereo sound.
I then reset (toggled through the inputs to "reset" the TV.
It finally worked but I was two days mulling it over.
See if this works for you.
My TV was a Panasonic Plasma, but shouldn't matter.
Skip the S-VHS line and connect the inoputs with the TV off.
You MAy need to go into the input of set up menu on the TV (ours had a wrench as an icon) and set the Component 1 or 2 to "VCR".
Aug 04, 2008 | Samsung Televison & Video
Sansui tv
sounds like the tv is on the wrong sorce
Apr 12, 2008 | Televison & Video
Hooking up JVC VCR/DVD Combo Player to LG 52" DLP TV with HTS
If you have pets check your cables and make sure they haven't been chewed on or pulled out or even loose.
Sep 28, 2017 | LG RU-52SZ61D 52" TV
Samsung dvd-v4600
Wish I could. I have the 4600 combo and the VCR works fine. The DVD stopped working many months ago and just yesterday started working fine again. Worked fine for two days and then stopped, picture froze, and all I got out of it, is the picture is loading. Wont give me back my DVD nohow, so have opened the case and stole it back. Tray will not open at all. Trying some repairs, will holler if succesful
Dec 20, 2007 | Samsung DVD-V1000 DVD Player/VCR
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Televison & Video Logo
184 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
