Question about Kodak EasyShare C663 Digital Camera
Lense stuck my kodak camera (the C663) is jammed in the outward position. its off and when i try to turn it back on it makes this wierd humming noise and turns back off. i tryed taking the batteries out charging them, nothing. i even tryed to turn it on then off quickly and tryed to help the lense back in.
  • 727 Answers
You have a cracked or stripped gear. If you ever took it to the beach it likely got sand inside. Even a little. You should try blowing out the gaps with compressed air from a can of air duster. If that doesnt work, you need it repaired
Posted on Feb 02, 2018
SOURCE: Kodak v550 digital camera
THANKS!! I thought my camera was gone for! This worked for me!
Christie
Posted on Sep 01, 2008
pumpkinman
  • 1165 Answers
SOURCE: My M863 Kodak Easyshare camera turns right off.
sounds like a power issue.maybe your batterysare no longer taking full charges
Posted on Jun 29, 2009
VinayT
  • 1884 Answers
SOURCE: kodak V1253 lense won't close
Use the vacuum cleaner to suckout the dust/sand particles stuck between the lens casing and the body.
Posted on Aug 11, 2009
SOURCE: my camera cannot turn on or off is only 3 months
1. Remove the batteries from the camera and the memory card
2. Batteries should be Li-Ion Rechargeable Digital Camera Battery KLIC-7001 3. Verify batteries are inserted correctly
4. Place the camera in Auto Mode (Its green camera icon on the dialing mode)
5. Turn on the camera (if it failed try charging the camera)
6. Plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
a. If lights on battery charging light [solid green]
>charge the camera until light turns off or (up to 3hours)
b. If lights on battery charging light [red or flashing red]
>camera batteries are weak; replace with recommended batteries
c. If lights on battery charging light has [NO light]
>Try new set of supported batteries to test the camera one last time
>If already tested with a new set of batteries, set up the camera for repair
8. After all the step still camera will not work contact Kodak support line at 1 800 235 6325 (23KODAK) ** since the camera is less than a year it can be sent for repair in warranty. To receive warranty entitlement, you need to include a photocopy of the receipt or proof of purchase
NOTE: If Kodak repair center finds out customer induce damage, you will pay for the repair cost
Posted on Nov 19, 2009
Testimonial: "very helpful thank u very much, i will definitely refer my friends to u! marilyn u.k"
leepania
  • 1099 Answers
SOURCE: THE LENSE MY KODAK M320 IS STUCK IN THE OUT
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping.
KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 07, 2009
Kodak V1253 lense won't close
Aug 11, 2009 | Kodak EasyShare Z1275 Digital Camera
Lens won't retract, stuck in outward position
battery power/and or lens motor/ if lucky the lense connection, (Try removing the lenses and puting them back) may be a bad electrical connection.
Aug 11, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
We have a C663 and C360 Kodaks. Both doing same
This problem is frequently the result of corroded battery contacts inside the camera. Remove the batteries and wipe the inside camera contacts with a soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Make sure there's no cleaning residue left inside the camera, then clean the battery contacts and reinstall the batteries. If this doesn't solve the problem you may have something more serious wrong with camera and I recommend checking the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format do diagnose problems and attempt to find a solution.
Jun 07, 2009 | Kodak EasyShare C330 Digital Camera
Kodak c663 camera not working !
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
Apr 24, 2009 | Kodak EasyShare C663 Digital Camera
My camera is Canon PowerShot SD870 IS. after i turned it on and the lenses goes outward as it should be but remained there even if i turned of the the power. i should mention it used to work properly.
That is lense trauma. I can be caused by dirt or lense being hit or zolted while open. Canons are strong cameras but if it make a grinding noise when the lense is trying to go back into the camera it most likely needs repair. try blowing the lens out with a hurricane blower or forced air. If the lense is tilted to one side even slightly no amount of forced air will help. good luck!
Oct 24, 2008 | Cameras
Zoom error
Hey MBB722,
What is most likely going on is there is something stuck in the lens obstructing its movement (i.e. sand). I don't know what you have tried and what you have not tried you can try placing the camera on a flat surface with the lens pointing upwards, and then press and hold the shutter button and while doing this turn the camera on. If this doesn't work you can try removing the batteries and waiting a minute or two and then reinserting. If these suggestions don't work you should have it looked at by an authorized service technician such as bringing the camera to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 01, 2008 | Fuji FinePix F470 Digital Camera
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Optical lense stuck in the "out" position
when i dropped my dx7630, a tiny plastic part broke that worked the holdback spring for the battery. Kodak has a repair service, or a referral service for repairs, but you have to send the camera in. i sent it in. they emailed me to say it was not a repairable part and didn't even ask if i wanted it back. luckily, i kept the memory chip. the C875 i bought was $100 cheaper and had 1M more pixels. good luck with your natural light photography from now on. i think Kodak just figures you buy a new camera whenever anything goes wrong, it'll be better and cheaper anyway.
Nov 14, 2007 | Kodak EasyShare C875 Digital Camera
Kodak EasyShare C663 Digital Camera Logo
64 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
