Question about Sony CDX-2250 CD Changer
Downt stay in channal memery
When i set my channels thin tarn the car of my channels do not stay programed,
  • 10,594 Answers
Make sure that yellow wire is also connected along with red wire to +12 volt line.
Posted on Dec 20, 2008
We purchased the midland two way radio, the problem is the channel we are on we only can hear every one in our group, but can not communicate if they are on their radio. How can we get on the same...
You should ask the others what channals they are on if you cant for whatever reason then scan for a frequincy that has others on it by hitting the scan butten and hitting the channal up or channal down butten, if you can tthen talk on each channal in order and wait 10 seconds for a reply then go to another channal and try agean, im not sure if you can hear others unless they have the same brand radio's but i could be wrong, i am also not sure if the scan butten will work so after it goes through all of the channals 2 times then try the other suggestion. you also want to make sure you have good batteries in when you try.
Hope this helps
Gamer71796
Feb 14, 2011 | Midland Two Way Radio
Need instructions to program tv
okay this is what you do hit the code search botton hit the tv botton the hit channal up untell you find that your tv is changing channals then hit tv again and that should work just do it slow becouse if you pass the channal it changes then you will have to use the channal back button tell it pops up again it will work.
Dec 09, 2009 | RCA Universal Remote Control
Coby tf-tv700 a 7in lcd tv will not git channals since diggital s
Go to menu pick rescan channels,not getting more channels,get digital antena.Rescan again.
Aug 15, 2009 | Coby TF-TV700 7 in. Portable Television
I only Get Channel 3 and a blank screen that says LINE
Under the menu setup, set it to cable (not "air")and do the search again. If there is a button on your remote that says input, push that first before trying this. Might save you some unneeded steps. Good luck.
May 22, 2009 | Panasonic PV-C2541 25 in. TV/VCR Combo
Cant get digital channal on my DCP 501
From page 24 of the Installation Section
The clear protective film on the DCP501 display must be removed and transferred to the inside back cover of your
DCP501 Home Theater System User Guide. The Unit Address and Serial Number found on the protective film is
required for activation of your DCP501 cable TV receiver by your cable TV service provider.
On Page 28 -
Do not disconnect the cable connection between the RF In and To RF In ports. Removal of this
cable could disrupt operation of the DCP501.
IMPORTANT! The digital cable feature of your Motorola DCP501 can be activated only in
certain cable systems throughout North America. Contact your local cable TV provider to
determine whether the digital cable feature of your Motorola DCP501 can be activated. In cable
systems where the digital cable feature cannot be activated, you may connect an external cable
receiver provided by your local cable provider. For best results, connect an external cable
receiver through the audio and video inputs on the back of your DCP501.
Page 74 -
Using DCP501 Cab le TV Functions
The DCP501 has an advanced CATV set-top terminal that allows you to view cable channels.
The DCP501 must be authorized for cable TV operation by your cable TV operator before it will
tune channels.
To use your DCP501 to view cable channels:
1 Press SOURCE to display C ATV on your TV. C A TV and the last channel tuned are displayed
on the DCP501 display.
2 Press MENU to display the TV program guide on your TV.
3 Press GUIDE to display the television program guide on your TV.
4 Change channels by pressing CHANNEL/PRESET���� or making your selection with the
If you receive an electronic message from the cable operator, the message icon �� turns on.
You must use the TV program guide to retrieve an electronic message.
Additional DCP501 cable TV functions include CATV Record and CATV Channel Scan.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Mar 21, 2009 | Motorola DCP-501 Receiver
Wharfdale TU320DTR channel settings
check the menu of your remote thin find the channel setings
Dec 30, 2008 | Televison & Video
Info service
Go to the Messages and then tap on info service and add the new channel with value 50. it will work now.
Thanks,
Rajendra
Nov 28, 2008 | Motorola Mobility ROKR E6 Smartphone
Magnavox 15MF400T/37 Channel chosen is not correct channel
Check the instrucitons to verify if the channel table is pre-setable to designate your own numbers.
Most TV sets have an autoprogramming for the channels. Look in the menu for the auto programming and let the set re-program the channels if your set has that option. This feature will re-program the channals, and re-set their defaults.
If the channels are not able to be pre-setable to a custom table, then this indicates that there is a pre-scaling fault in the tuner or in the uPC. In this case, the set will need service.
Jerry G.
Mar 25, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Samsung tv problem
Hi.
You havent listed your TV model but most Samsung sets that are digital will have A button on the remote marked DTV this will tell set to look at the digital chans.
Now try & go in to the menu & select tuning & scan the digital chans in.
One other thing are you in an area of the UK that can pick up digital channels without changing your aerial.
http://dysonmanuals.llc.nu/
Chris..
Mar 07, 2008 | Televison & Video
HELP!!!
Go back in the menu, find (input source) or (tuner) then click the cursor right side of the menu button or the left to move the (TV) to (CATV), after you bring it up then move cursor arrow up or down to page (AUTOPROGRAM) then tap the cursor arrow right of the menu button to start the CATV channels to be found , be sure you have the cable connected to the TV. Once the channels have been found, tap (EXIT) or (STATUS) button on remote to get out of the menu and close the page, or just turn set off and back on again.
May 29, 2007 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sony CDX-2250 CD Changer Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
