Question about KitchenAid KGST307 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Are the two igniters found in the oven (one for the oven and one for the broiler) on a KitchenAid Thermal-Convection range model KGST307 the same (part # 748248)? The lower igniter in my stove appears to be out but the broiler works fine. They appear to be the same but I wouldn't want to order an igniter and discover I'd bought the one for the broiler by mistake. Thanks much JustaGuy
  • Guy Cardineau Apr 02, 2007
    The full number for my range is KGST307GBS0 (sorry 'bout that). I searched on RepairClinic.com and found a single igniter, which is their part # 748248. My part is about 3.5-4 inches in length, which seems to correspond fairly closely to the picture of 7482448, and both the broil and bake igniters in my range look identical. I looked up the part #'s you provided and found their part # 747868 (~7.5 inches) corresponding to 9751123 and # 748013 (~11 inches) corresponding to 9751784. The lengths are basically related to the glow bar, ceramic extension and the metal cover over the glow bar attaching it to the ceramic. They all look very much alike except for the lengths and the color of the ceramic material (white or brown) holding the glow bar.
    Guy
  • jgiambro Mar 13, 2008
    I have the same problem on my KGST307B4. The broiler works, but not the oven. Sounds like the solution is to replace the igniter for the oven. How tough is the job?
What does code F1E3 mean in a kitchen aid superba model KGST307HBL9?
Posted on Aug 26, 2008
    President:
  • 878 Answers
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Posted on Apr 02, 2007
  • Ron Marek
    Ron Marek Apr 02, 2007
    Guy, the model number helps. They are the same, part number 9753108, right out of the book. Catriver...
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler works but lower over doesn't?
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb2_bing.gif, the more you cook, the faster it wears out. Bottom line, needs to be replaced. The broiler has its own ignitor. Good luck.
Jan 19, 2010 | KitchenAid KGST307 Gas Kitchen Range
I have a Whirlpool Gold oven model GW395LEGB5 that won't heat. The broiler works fine. Sometimes, after the broiler is lit, the oven will heat up. But no more. Just the broiler works. Is this...
If the broiler works fine, but the oven does not, more than likely this is caused by an igniter that has gone bad. The intermittent symptoms you were experiencing is a sign that the ingiter probably became weak due to age and finally failed. The following link explains how these igniters work and how to replace one:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since both oven manifolds are fed from the same gas source, this can be narrowed down to an igniter problem. Your oven should have the Norton type igniter. The part number for a replacement is 9782065 and can be found at appliancepartspros.com for about $71, You can search around if you like, but this was the cheapest I could find it.
Your oven has interchangeable igniters. Meaning the broil manifold and bake manifold use the same type of igniter. You can swap igniters while awaiting parts, if you wish to use the oven to bake.
NOTE: If the connector plug on the ingiter you receive does not match the receptacle in your stove, you will instructed to cut the leads and connect them together using ceramic wire lugs (included in the kit you receive). Do not attempt to use standard wire lugs as they will melt. The wires and ceramic lugs are heat resistant.
If you have any questions, or need additional assistance, please let me know. I hope this helps you.
Sep 07, 2009 | Kitchen Ranges
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
Broiler
can you hear the convection fan motor turn on? if not that would be your problem.
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven not working, but broiler is...
Very well could be. I'm assuming the bake burner is the problem, right? Does the igniter glow at all? If it is glowing, but the burner does not light, is it usually a symptom of an igniter that has become weak. If it does not draw enough current the gas valve will not open and the burner will not light. This is a safety feature to prevent free flowing gas without ignition. If the broil burner is functioning properly, then more than likely the gas valve and regulator are working fine. In most ranges both burners are fed from the same source. You could try swapping igniters between the broil and bake burners to prove the theory. Or, you could just replace the igniter all together. Current readings are as follows: Round shaped glow igniter: 2.7 to 3.2 amps Square shaped glow igniter: 3.2 to 3.7 amps If you can give me the exact model number off your range (usually located around the oven door or on the back of the range) I can give you the correct part number you will need. Most appliance repair stores carry the igniter. I hope this helps you.
Sep 14, 2007 | KitchenAid KGST307 Gas Kitchen Range
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler and oven igniter the same?
you may not need a igniter. the problem could be with your control board which supplies power to both the broil igniter and the oven igniter. In my years of working on ovens i have not seen a oven that needed both igniters replaced.
Mar 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KGST307 Gas Kitchen Range Logo
1,747 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
