Question about Sony DRU-710A DVD±RW Dual Layer Burner
Sony DVD RW DRU-710A
Hi, i'm hoping you can help!
I have the above dvd drive installed in my computer its internal, earlier this week i bought the dark knight dvd and the drive started making noises like it was trying to read the dvd but couldnt manage too and so the dvd didnt work.
The extras dvd did work so i assumed it was just the movie dvd which was currupt but i got it to work on my playstation 2 dvd player....
anyway its been a few days and i finally came back to using my sony dvd rom and its not reading anything now wont read cd-r's or dvd's any of them it makes the same noises like its trying to read them but cant and in the end says to insert a cd in the drive...
i uninstalled it and allowed windows to reinstall it but that still didnt help.
Has the drive itself somehow damaged itself and needs some sort of physical repair? or its completly gone and so i'll need to buy another one or is there some explaination?
it should be noted since the last time i used the drive a few days ago and today when i noticed this problem i did update my microsoft stuff the automatic update and i also tried to use system restore which didnt help.
hope that made sense
Billy
(thething18@hotmail.com)
    Master:
  • 507 Answers
Sounds like the DVD drive is in need of some repair there if its making some odd sounds and miss reading CDs and DVDs also make sure connections are good behind the drive
Posted on Mar 02, 2017
4 Suggested Answers
SOURCE: Sony DRU-710A doesn't write others than DVD+RW anymore
I updated the latest firmware provided by sony and could solve the problem.
Regards
Hannesfx
Posted on Feb 11, 2008
  • 8 Answers
SOURCE: Sony DRU-710A DVD±RW Dual Layer Burner?
First I need a little more info from you, what operating system are you using( windows XP,Windows Vista,Linux?) What software are you trying to burn the DVD with?
What Happens when You try to burn the DVD,Do you get errors or crash or what?
Let me know I can see what I can do to help
wwiz
Posted on Oct 13, 2008
  • 212 Answers
SOURCE: Sony DRU-710A Installation without the disc.
check sonys website for the drivers for it. If not try what you said. Good luck.
Posted on May 24, 2009
May 24, 2009 | Sony DRU-710A DVD±RW Dual Layer...
Wont Read OR Burn DVD's
Hi There that is a hardware failure inside the unit there are two different lasers in the one head one for cd and one for dvd it sound like the dv d head has failed if the unit is new or under warrenty its time to speak to your supplier or if not bite the bullet and invest in anew unit
sorry for the bad news
Regards AL "Alstech"
How to Install Sony DRU-710A DVD-RW
Cd/dvd drives don't actually require a driver to run. They use "class filter drivers" which are supplied by a burning program like Nero or NTI. These "class filter drivers" only add functionality to the drive. Windows just uses a generic driver "MSCDEX" to run them.
A couple of things to try:
Uninstall the drive. Open Device Manager, click on the + sign next to CD/DVD ROM drives, right click on the drive and select uninstall. Exit and restart your system. When windows loads, it will recognise a hardware change, and will ask if you want to install. Before you click anything, insert the disc that came with the drive (if you have one). This should then install, if not, let windows search. If windows can't find anything, select "I will choose the driver manually" and look for your drive in the list.
Another thing to do, is download the most current Chipset drivers for your motherboard (which I would recommend anyway, even if the above worked).
Update the Firmware version and the internal drivers for your drive. These can be found here: http://sony.storagesupport.com/product/112#drivers
Also, update windows to the latest Service Pack (SP3 for XP and SP1 for Vista) if you haven't got them already.
If you have Vista, did you recently update to SP1 via Windows Update? If the answer is yes, please let me know.
Hope these solve your problem
Regards,
Tim
Dec 09, 2008 | Sony DRU-710A DVD±RW Dual Layer...
I have window xp my dvd burner worked fine before now it doesnt
What do you mean "it just stays there"? Can you be a bit more specific? The writing speed doesn't really mean anything apart from being able to burn quicker.
The "drivers" for the sony dru 710a can be downloaded from here:
I would also update the Firmware version too.
Hope that works
Regards,
Tim
Nov 14, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Instalaion
You don't actually need a driver. All cd/dvd drives are plug and play. All you need to do is plug it all in to your system, turn it on, and Windows will do the rest. Once Windows has installed it. You can update everything from here:
Hope this solves your problem
Regards,
Tim
Oct 28, 2008 | Sony DRU-710A DVD±RW Dual Layer...
wwiz
Oct 13, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Power caliberation error
Try uninstalling your burning software and then re-installing it.
Try uninstalling your drive, restart, and let Windows install it.
Download and update your Chipset drivers (recommended)
Update to the latest Windows Service Pack (recommended)
Uodate the drives Firmware version and internal drivers:
Regards,
Tim
Aug 25, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Regards
Hannesfx
Feb 10, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU 710 not writing DVDs or CDs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking Sony for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays
Jun 20, 2007 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU-710A DVD±RW Dual Layer Burner Logo
137 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
