Question about Braun 150 Electric Shaver
Braun 5705 Shaver side cutter is not operating !
Braun 5705 Shaver
The side cutter does not work.
Please advise !!
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
SOURCE: braun 360 shaver. How to replace the cutter.
yup, it worked. Just pry it up. I used a heavy duty tweezer.
Posted on Feb 10, 2009
brector3
  • 1629 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
SOURCE: how to disassemble Braun 4505 shaver. Cutter stopped working.
You want to go to this site and get a repair manual. http://web.archive.org/web/20041025223715/63.230.9.155/braun/Srv_Man/SHAVER/
Follow the instruction and remove the swivel head. Then remove the 2 screws at the bottom. I still have problem sliding the two side head support off.
Posted on Feb 28, 2010
brector3
  • 1629 Answers
SOURCE: I live in County Cork,
You will find parts for all Braun shavers on-line at shaveroutlet.com. They will ship to you in Ireland at a reasonable cost
Posted on Feb 01, 2011
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Blades need sharpening or replaced. Where do I go in JHB area
Braun syncro 7526 foil and cutter blades is Braun Series 3 combi 30B foil and cutter replacement pack.
Apr 18, 2011 | Braun Syncro 7526 Electric Shaver
Series 3 - 340, my father wants replacement foil & cutter, where can I order one from please.
Braun makes two distinctly different models, both with called seroes 3-340. You will need the type number as written on the shaver to properly identify the correct foil and cutter for his shaver. Both types are available at shaveroutlet.com. See the two links below. You will need to use the type number of his shaver to select the correct one of these two
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-foil-and-cutter-p-141.html
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jan 11, 2011 | Braun Health & Beauty
Where to get and how to replace the shaver switch on 7680?
The switch is part of the outer case and can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-syncro-body-housing-select-models-p-811.html
To replace, you will need to gently pry off the cap that surrounds the cord hle on the bottom. Once removed, the side grips will pull away easily revealing 4 screws on the back. Remove screws to take the bask of case off and then lift out the 'guts'. Reassemble in reverse order
Sep 30, 2010 | Braun Syncro 7680 Electric Shaver
The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
May 27, 2009 | Braun Syncro 7526 Electric Shaver
Removing BRAUN 1775 Cutter Block
Hi Miller1292
Braun have great user manuals with good pictorial instructions on how to service your shaver. To get a copy for your shaver, go to this site
Be sure to pick one that is in English:) Thanks for using FixYa, a FixYa rating for my solution would be awesome. Cheers
regards
robotek
May 07, 2008 | Braun FreeControl 1775 Hair Trimmer
Braun 150 Electric Shaver Logo
121 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
