Question about Sony PlayStation 2 Slimline Console
Broken ps2 slimline , sounds like the disc is catching sumthin, any help? could it be the draw, still isnt working, help??
When i close the draw with the disc inside it sounds like sumthings catching and makes a racket and then just dosent work properly
Ok the problem i had was the disc would not read and it sounded like struggling to read. 1/ if under warranty-use it 2/if not you need a small phillips screwdriver and a flathead screwdriver. Take the back soft pads off and unscrew x2.then use the flathead and unclip hard plastic (not rubber)front ones x3 and x1 back. Carefuly remove the top avoid touching the laser lens at all cost(this will cost you) Now to the problem The lens slides back and forth on the steel rods, i found that mine was sticking in a spot i put some crc on a tissue and cleaned the steel rods. Too test while still open put the leads in and (power last) and turn on .In order to fool the machine to think it is shut there are 2 trigger point to push down 1 next too the on button and the next is white and in mid-back when done together the disc will start to spin.(hopefully that was your problem as mine went back too whisper quiet and all my discs worked again) and just go in reverse to put back together Good luck and enjoy the experience
Posted on May 13, 2007
Spindle motor wont spin and lens are clicking ! ps2 slim problem!
seems like you need to go buy a lens cleaner from bestbuy or something. Run it repeatedly untill it works. sometimes it takes a while. But it will work after. please rate@
May 05, 2011 | Sony PlayStation 2 Slimline Console
My PS2 slim wont spin a disc it takes you to the game settings but nothing else
Well has it been dropped? If so more then likely the guide rail fall out of place and can easily be poped back in place. A good way to see if its your laser or guide rail is to fined the hole that when the lids closed this pin goes in the hole so the ps2 knows the lids closed and stick a piece of paper in that hole with lid opened. Now it should act like the lids closed. See if the laser produces a red beam or strange noises. Maybe even the little black piece at the back that stops the disc from spinning isnt working right. But dont get worried as theres a pin on the lid that makes the black piece pull back from the disc when lids closed so it might be stopping disc from spinng while its open. Several diffrent solutions need to know how you know its not spinning. If your just putting your head to it and cant hear it spinning then you will need to trouble shoot.
Nov 21, 2010 | Sony PlayStation 2 Slimline Console
Ps2 slimline not sensing disc
Try this solution. Its for a regular PS2 but it is the same concept.
Jun 20, 2010 | Sony PlayStation 2 (PS2) Console
Looks like the disk isnt spinning - any ideas what to do?
Yes. There are three reasons why your Slim PS2 disc might not spin.
1. Bad laser. This is the most common issue.
2. Bad case: if your PS2 dropped or is banged around a lot, the case could become loosely closed and even though it is closed, the PS2 thinks it is still open.
3. Bad sensor(s): The PS2 has 2 sensors to let it know that the lid is closed. Once the lid is closed, the laser does its thing.
http://store.richspsxparts.com/slpsnospdi1a.html
The website above shows you how to check for these problems, and sells parts to fix them all. They also do repairs.
Oct 04, 2009 | Sony PlayStation 2 Slimline Console
My disc wont spin
Hi....
It's probably a broken disc brake post . It comes down off the cover and pokes into a square hole in the back-right-hand side of where the disc lid hinges.
If there's no post the disc wont spin when you close the cover.
If it's broken you can drill a spot where the other one was and glue a plastic piece in its place.
Mar 23, 2009 | Sony PlayStation 2 Slimline Console
Slimline PS2 makes weird noises
u gota change ur ps2 lens...this problem always occures when the lens gets old!
ur only choice is to change the lens! and you can't do it alone! have to take it to experts
Sep 16, 2008 | Sony PlayStation 2 Slimline Console
Ps2 slimline repairs
Its about the programming of your PS2, the only solution i now is to buy a new PS2.
Jul 31, 2008 | Sony PlayStation 2 Slimline Console
Disc dosnt spin, but laser moves fine
This is the most common of the two problems with ps2 the one you have is the second most common problem the first being the laser itself not working and then you problem disk not spinning.
As you know the laser is moving the rules out the door catch mechanism being a problem so all thats left is the laser unit itself now your problem is the motor on the laser not working but the big problem you have is you just cant replace the motor on its own it comes as one unit with the laser.
Now buying one isnt a problem neither is fitting it but the problem is calibrating the new laser to do this you nedd osciloscope and these cost $1000 to buy so unless you have one then this is a problem also if you take it in to be repaired the repair cos allone would cost more than a new ps2 so it just isnt worth repairing if you look on a well known auction site you will see thousands of ps2 with your problem they just dont repair them any more its just not worth it.
youd be better of buying a new one it would be cheaper than the repair and also buying a new one means that it will last a bit longer.
Say you get yours repaired then next week it overheats then you have another problem related to the age of the console so at the end of the day it would be best to buy a new let me know if you need more help or advice.
Also the problem with the slimline one is you can adjust the laser because on the bigger ps2 you could adjust the laser by hand and get it to work again without any special tools but sony done away with this feature so that they got people to pay for repairs sorry i couldnt give you good news ok
Feb 15, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim wont turn on
You might try a friends ps2 power supply of the same type to make shure it isnt the ps2 that is broken. If the friends power supply works, get a working one from ebay or something.
Dec 26, 2007 | Sony PlayStation 2 Slimline Console
Ps1 games wont play on slimline, broken sword game comes up as insert a playstation or ps2 disc,can this be fixed?
Is it a 'chipped' game (a copy) or is it a real game frsh from the shop. if it is a copy then it will not work on your PS2.
Good Luck
Mick
Nov 15, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
130 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
