Question about Maytag MAV8600 Top Load Washer
Squeeling Noise (from the pully pump I think) Maytag MAV8600AWW
I have a top loading Maytag MAV8600AWW. I can hear a loud squeeling noise that sounds like it is coming from the pulley pump. Everything still seems to work correctly. Does anyone have any idea if it is the pulley pump, the belt or something else? Any help you can give me would be appreciated. Thanks.
  • 179 Answers
You need to replace the pump the pump bearings are starting to wear out eventually the washer will not drain
Posted on Dec 20, 2008
Front end squeeling noise on 2007 honda accord
could be the power steering pump itself. If it has a bad bearing it will do that. Especially when you turn it makes the steering pump work a lot harder.
Aug 31, 2017 | 2007 Honda Accord Sedan
When i put my belt back on my 98 mercury grand marques it started making squealy noise when the car is on
I am assuming your talking about the serpentine belt, you need to check all the pulleys that the serpentine belt rides on, P/S, alt. ider pulley, A/C, tensioner. water pump, if everything seems good, put the belt back on and locate where the sound is coming from, use a wood dowel to hear exactly what is squeeling.
check the power steering fluid.
Mar 04, 2011 | Mercury Grand Marquis Cars & Trucks
Washing Machine staring making a grinding noise now it broken!
No, not the motor. The pump has a steel sleeve that has come up out of the pulley and has locked down the pump. Replace the pump and you will be fine.
Jan 27, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mav8600aww grinding when agitate
post your email i will send you the service manual
Jan 26, 2008 | Maytag MAV7600 Top Load Washer
Loud noise -- water pump??
Yes you definately need a new pump assembly part number 21001906 $59.95. That is a maytag part number and it is a very common repair. The new pump is a revised design and will look different but will mount the same. Axcess through front panel.
Nov 25, 2007 | Maytag MAV7200 Top Load Washer
Maytag Atlantis Mav8600aww
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Apr 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Open Questions:
Maytag MAV8600 Top Load Washer Logo
295 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
