Question about Maytag Microwave Ovens
Keypad on our microwave is malfunctioning
The keypad is either dead or sometimes functions, but keeps beeping and asking for timer input. We usually unplug and replug it a number of times and finally it works once or twice and then we'll hear it beep and ask for the timer input. It will continue to beep at randum times asking for this until we unplug it again.
Thanks for your help!!
  • Maytag Master
  • 9,098 Answers
You have a shorting membrane keypad. If the oven is coming on by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
Posted on Dec 21, 2008
Microwave error message that says it may need service, keypad shorted.
You can probably get behind the control panel to look for bad connections, but anything more requires special security screwdrivers. Make sure it is disconnected before attempting any repairs.
Google
microwave repairs <my city>
May 13, 2016 | In Microwave Ovens
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave started running by it's self. It first said 3.5oz and would not stop until door was opened. then it started beeping and wouldn't stop until door was opened. we unplug hoping it would reset...
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Dec 10, 2009 | GE JVM1440 Microwave Oven
Microwave is beeping, lock comes on, F2, just keeps beeping by itself
F2 on a KitchenAid mike usually means a Keypad short. Beware if it is a KHMS155LSS, it can self start on its own with a KeyPad short. A real stunning defect.
Sep 08, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
LG Microwave Beeps 3 times, display shows F3 and keypad dead.
Since it's less than one year old, it would be fully covered under warranty.
I'd suggest returning it to the dealer or contacting the manufacturer to get it fixed free.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. You can get warranty info & find a local authorized servicer.
Jun 03, 2009 | Microwave Ovens
Microwave beeps, error codes display and keypad stops working
It sound like you have a bad keypad or controls.
Is it possible that moisture from the sponge is getting into the controls?
You might contact the manufacturer to see if there might be a recall. I've seen keypad recalls in the past.
Anytime the keypad is suspected of coming on by itself, the oven should be unplugged when not in use.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Cuisinart CMW-100 Microwave Oven
I've replaced the keypad and computer on my kems378gss3 Kitchenaid microwave oven/oven combo. Everything works EXCEPT that the microwave doesn't actually cook, and the timer set-start button doesn't work....
I would suggest to check all the connections from the new installed parts and double check your switches.
Have you followed the user guide from page 35 to try to unlock that key?
If still does not work, there may be two possibilties that the new keypad(timer set-start button) may not work or the magnetron is defective.
Check this link as well for some additional info.
Mar 07, 2008 | Microwave Ovens
Microwave Ovens Logo
104 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
