Question about Volfenhag ZX-8200 Car Audio Amplifier
Protect light Have power protect light is on, with no sound..
  • Anonymous Apr 14, 2009
    The protection light stays on and there is no sound and the amp isnt actually on.
  • 15,935 Answers
Check speaker wire is not grounded and/or the proper impedence is followed. Those amplifiers are 2 ohm stereo stable. Know the difference.
Remove speaker wires and try amplifier.
Add 1 speaker at a time until the problem recreates itself, or test them with an ohm meter.
Posted on Dec 21, 2008
  • blueextc3221
    blueextc3221 Dec 21, 2008
    check speaker wire is not grounded and/or the proper impedence is followed. Those amplifiers are 2 ohm stereo stable. Know the difference.
Amplifier protected LED on. what to do
Take it to the repair shop. Something is blown.
Apr 26, 2015 | Music
Protection light flashing and alarm sounding, unit was running and the unit just quit and the flashing light and alarm came on
Will the unit power up without the cb radio? I would suggest a short somewhere in the system if the protection light continues to shine bright.
Mar 24, 2013 | Pyramid (PS36KX) 600-Watt Power Supply
The protect light is the only light that comes on
Either one of the amps or the power supply has blown. The protect light means the power supply has been shut down due to overcurrent. Take unit in for repair. These are hard to work on due to packaging.
Oct 10, 2010 | Fender Passport Deluxe 500watt Sound...
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
I have a yamaha m65 power amp. the amp lights up but the red protection light stays on. no sound.
the power amps are blown and need replacing, the protect circut is stopping any further dammage
Oct 06, 2008 | Audio Players & Recorders
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
My amp wont put out sound
it's blown....probably, check your connections and make sure your presenting it an ohm load it can handle....so check the sub with a dmm.
Feb 28, 2006 | Jensen A600HLX Car Audio Amplifier
Volfenhag ZX-8200 Car Audio Amplifier Logo
169 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Morne Olivier
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
