Question about Omron HEM 650 Wrist Blood Pressure Monitor
I start the monitor, it starts to tighten the cuff and then stops
The cuff will not tighten. Put new batteries in. shows a "E"
  • lupe6918 Jan 12, 2009
    it would just not work even with new batteries! it doesnt tighen and when it does the beep sound doesnt come out
I had the same problem. I moved the device about 1/2 inch up my arm and it begain to work again. I hope this helps.
Posted on Oct 20, 2009
  • 74 Answers
Here is the site to download troubleshooting and manual info. I hope this helps.
http://www.omronhealthcare.com/product/s1-1126-186-manual-monitor
Posted on Dec 25, 2008
Only memory works on y HEM-711 start stop button does not work . Is it worn out?
Time for a new machine. That could be the controller or the switch board that is bad. You cannot get parts.
Oct 06, 2016 | Omron HEM-711 IntelliSense Automatic Blood...
How do I fix a homedics BPA-201 Digital Blood Pressure Monitor. Or who do I send it to be fixed. It keeps displaying E1. But I checked all cuffs connections and they are fine.
Are you moving your arm at all after you press the start button. I just have a wrist cuff, but if I move anything after I've pushed the start button I get an error code.
Apr 02, 2015 | Homedics Health & Beauty
What does error 3 on my microlife blood pressure monitor
Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
Jan 10, 2015 | Microlife Health & Beauty
Monitor starts normally but on it's way down, the number drops down dramatically
check for leaks...i have opened one of this before and it has a broken hose inside...but before going anywhere else, try to check your cuff near the hose then the hose fittings for possible sign of leakage...
you can inflate your cuff then submerge the hose and cuff in water to do the check...
May 17, 2014 | Omron Bp785 10 Series Upper Arm Blood...
The blood pressure monitor reads error 1
make sure you are getting the reader part on the artery just above the bend in the elbow. you may need a new cuff.also make sure it is snuggly plugged into the machine.
Apr 07, 2012 | Mabis ® Automatic Premium Blood Pressure...
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Dec 04, 2009 | Timex Health & Beauty
WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
When the pressure comes up on the monitor the top number was reading EE. It did it three times. I can't find the instructions. The machine is an Omron model: 741CREL. Thanks.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Feb 21, 2009 | Omron Automatic Blood Pressure Monitor...
Does not inflate, even after NEW batteries and reset of data.
its seems like when you were doing the settings for your monitor you didnt take it back to the start position so you need to read the instructions from your papers and go back to the begining and restart all over with the settings, it seems like you have knocked off the settings somewhere which also controls the inflation of the cuff and the cuff will not inflate while the settings are not set right so restart from your instructions and see if this will help you. good luck!
Jan 24, 2009 | Omron HEM 650 Wrist Blood Pressure Monitor
Omron HEM 650 Wrist Blood Pressure Monitor Logo
424 people viewed this question
Top Omron Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Maxumized
Are you an Omron Health and Beauty Expert? Answer questions, earn points and help others
