Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Display not working
The display isn't working but the oven and eyes are. Please help!
  • Anonymous Feb 16, 2008
    I have a Jenn air SCE30600 slide in range. The oven lights are on but the panel above is dim so it's not possible to turn the oven on or anything else. The cooktop is fine. Where do I get the manual and the part that's needed, etc.
    Sergeant:
    Champion:
  • 362 Answers
The most common remedy is to replace the LED readouts in the oven they burn out they are light emitting diodes, that sometimes dont last long.
Posted on Dec 08, 2007
SOURCE:
Amana Eletric Range, not working
check to see unisulated wires......but dont forget to turn the breakers off.by the way use electrical tape to insulate open wires.
Feb 05, 2014 | Amana AER5844VAB Electric Range
Have Maytag MER5755QAW range, the oven will not heat up, the display was working isn't now, i check both elements and temp sensor, all ok
The display control will need to be replaced. It may be cheaper to replace the unit since the control is so expensive. Here is a link to the part you need.
Keep me posted!
Jan 21, 2013 | Maytag MGR5880BDS Gas Kitchen Range
My cooktops eye stopped working
Is the oven not working as well? If it isn't working check your breaker for that appliance.
Oct 06, 2012 | Frigidaire FEC36S6EB
Touch button won't work
If all buttons don't work then check that connection isn't broke through the I/O board.
If not then board is faulty.
Is you display is lightining or not.
if not then the connction is bad
thanks
please rate my work
Sep 10, 2011 | KitchenAid KHMS155L Microwave Oven
Display and clock will not light up. have power. will make beeps when buttons are pushed. oven will heat up
check the display cable that it isn't get damaged or loose.
thanks
please rate my work
Sep 03, 2011 | Microwave Ovens
I don't know why my microwaves keep beeping and starts the Exhaust Fan automatically every 5 mins. The display says F-3. Please help me with the problem I'll appreciate.
F-3 is usually for the temperature sensor being faulty. What you need most likely is to replace the temperature sensor. This would explain why your microwave oven exhaust fan keeps going off, because your temperature sensor is telling it that it is overheating even though it isn't.
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
I have a Whirlpool Model # GY396LXGB5. The clock is displaying the following E1 - F1 code. We can't turn the oven on. All eyes on the stove top are working.
Hi
Thanks for using FixYa. F1-E1 error indicates that the control board has gone bad and should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Ovens
One eye on my oven won't heat..could this be the fuse or element
This could be caused by the eye control switch,the eye itself is bad,or the electrical block where the eye itself plugs in.These can be checked with a volt/ohm meter.Also a wire could have burnt under the stove top.Hope this helps. Gregg
Jun 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
138 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
