Question about Philco 841.169 Turntable
Philco 841.169 turntable does not start
It does not start because the display keeps showing the word "LINE" and I do not know what do in order to start the turntable. It worked until a couple of days ago.
3 Suggested Answers
ttech
  • 139 Answers
SOURCE: turntable won't turn
In the middle of the TT youll Find a C-Clip It needs to be Removed before the Platter can be removed,You either have a Broken Belt,Or the Grease in the Guide is Old and must be Cleaned out and Relubed
Posted on Jul 19, 2007
  • 104 Answers
SOURCE: I have Philco 841.169 model
about 3% of the time the 'brains' get scrambled, try unplugging it from the wall for a few minutes, sometimes this will 'fix' it.
if so, a power surge from your power company might have got it confused, if the problem continues try a surge protector power strip.
Posted on Feb 11, 2009
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
May 06, 2010 | Philco (R) 841.205 CD Shelf System
Need a replacement needle for a Philco turntable that has a Diamond needle? The model # is a 1962 Philco Stereophonic High Fidelity model # K-1636X-121
Check lpgear.com for Philco stylus replacement. You may need to find the "Contact Us" tab and request information for your particular model, but if they can't help you, then contact Philco (division of Ford Motor Co.)
Jun 28, 2009 | Audio Players & Recorders
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Apr 20, 2009 | Philco (R) Classic Turntable CD Shelf...
Turntable not working
http://www.archive.org/details/Turntable_Belt_Installation
above shows the general installation method for virtually all turntables. If it keeps falling off, you will need a new belt.
Feb 03, 2009 | Philco 841205 Turntable
I have Philco 841.169 model and when I press the phono button so I can play an LP, it keeps showing the word "LINE" what does this mean and how I can start my turntable?
Dec 20, 2008 | Philco 841.169 Turntable
Power supply
This unit takes a 12V 0.5A DC power supply. Your local Radio Shack sells this type of supply that will plug into the wall. You'll need to make sure that the other end will plug into the turntable, but for the supply, Radio Shack is probably the quickest way.
Jul 24, 2008 | Philco PC-841.651 Turntable
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Turntable belt
The Belt goes arond the Inside rime Of the Table as you do this you will see a Motor thru the Opening there should be a Guide there that keep the Belt stright,(Unless the Belt is Rubbery,And at which Point Go to PRB Belts and Order one
Jul 19, 2007 | Philco PC-841.651 Turntable
Philco 841.169 Turntable Logo
32 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Morne Olivier
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
