Cobra LI 7020 WX-EVP  Two Way Radio Logo
A
Anonymous Posted on Aug 21, 2012
How to fix the auto squelch on a cobra li7020wx hand held it is noisey all the time
I have the manual it didnt help to fix problem with the auto squelch
DROPNDEAL
Level 3:
Top Expert:
  • Cobra Master 2,931 Answers
  • Posted on Feb 02, 2018
DROPNDEAL
Cobra Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
930763
Points
21770
1 Related Answer
Anonymous
  • 2080 Answers
  • Posted on Mar 28, 2011
SOURCE: need instruction manual for cobra hand held serial
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
https://www.cobra.com/downloads/manuals/LI7200WX_MANL.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
Please comment back here to this page if you have any questions, have difficulty accessing the link, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
1helpful
I have MRHH325 squelch has stopped working ant idea's please
either take it to a tech or open the unit and find the variable to adjust the squelch . you will need a signal generator and a scope so you decide.
Squelch won't turn off, won't go into power save mode
Power-save mode means the radio is being turned on and off repeatedly, to save power. The radio turns on, & if it hears any signals (i.e., if squelch circuit determines a station is being received), it turns on the speaker; else it turns off again to save power. So, squelch and power-save modes work hand-in-hand, and your problem is squelch circuit is either set too low, or a station is being received by the receiver. Download/look at the owner's manual and adjust the squelch circuit for a higher setting, and it should go into power-save mode again.
Good luck.
Can't break squelch ? Have Uniden Bearcat hand held scanning radi
Look at the squelch knob. If it is turned fully counterclockwise, it is in "Auto". Turn the knob clockwise to enter the manual mode and adjust the range untill static is heard. Reverse direction until the static is no longer heard.
2helpful
The squelch not working on a cobra 29 wxnw st sound tracker
there are 3 or 4 horse shoe presets inside the radio i suspect that the squelch preset is needing turned up. try turning one up at a time. remember to put it back to where it was if it is not the squelch. use a plastic screwdriver do not go putting metal screwdrivers into your radio in case of shocks. hope this helps you
No Auto Squelch on Cobra PR4700WX
Yes sir, when u will open the set u can find two potentiometers , one is for tranmitter another for receiver . Try adjusting the same ( second radio should be transmitting ) do not switch one radio without antennae it may burn ..
Regards
raj/
1helpful
2answers
Cb radio
Go onto google and search Cobra 29ltd schematics and find where the squelch level and your AMC control is at Automatic Modulation Control. It should be Vr4 for the amc turn it up all the way clock wise with the radio facing toward you then back it down so your not over modulating. Then when you find the squelch level you can turn it down to qiuet it down.
Cobra microtalk2 auto squelch not functioning
Dear sir,
Use maximum range button which is also light button ( keep it pressed for 5 sec ) u will hear a beep , then relase it operate ur radio in High power transmission mode , ( channel 1~7 ) or 16-22 ( ckeck ur country lcense guideline before that ) .
Regards
Raj
No book looking for help
Hi, Looked for a book thru google, but no luck. I did see where they have an automatic squelch. The auto squelch should keep them quiet till someone keys up.
Features, 14 channel, no GMRS, 1/2 watt output, LCD display, autosquelch, rechargeable battery pack. That's about all I can help you with,, Mechanic good luck.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
