Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
Have a powershot sd550
I have a canon sd550 ,when i put memory card its showing memory card error and card locked,but card is unlocked position and its right way
  • lkensington Dec 28, 2008
    Keeps reading Memory card error and Memory stick locked....
  • 6,831 Answers
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
Memory card when insert camera show card locked. can I delet the switch for card lock?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 21, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
I have a Sd550. All the screen says is memory card error. Memory card locked. What do I do?
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 23, 2010 | Canon Cameras
Screen has memory card error on it but when you go to program it won't let you go to format
If the card is an SD or SDHC card, check to see that the slide switch on the side of the card is in the "unlocked" position.
Nov 10, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Memory card error
I assume that you know that there is a tiny tiny on-off switch on the edge of each SD card. If they are locked in the off position....
Apr 29, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Card Locked
If your card is locked, there is a little swith on it. Push it to the unlock position. If it is your camera, I have never heard of such a thing. Call Canon.
Mar 19, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
The memory card is locked Taped side hole and switch in up position...I think unlocked. Still says card is locked.
you need to put memory card into computer and format it. your computer should pick up the memory card.
Feb 07, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Memory card error (states memory card locked) not locked
Remove the card and look for a tiny slide switch on the side of the card. Slide this switch to the other "unlocked" position. Reinsert the card and try it out.
Jan 11, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Hi. My Canon Powershot sd400 is telling me there is a " memory card error"...and "Card Locked!". Any idea how to fix this? Heidi
Hi!
You have to unlock your memory card. All memory cards have this small lock mechanism on the side.
Make sure that the slider is on the UNLOCK position. If it's already on the UNLOCK position and you are still getting the same error message, try to set it to LOCK, then set it back to UNLOCK position.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Feb 28, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
155 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
