Question about Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher
Unit not pumping on wash cycle
Unit will fill and discharge water, but won't pump on wash cycle.
Any help would be appreciated.
Thank You.
  • 38 Answers
Could be bad main wash pump motor, bad capacitor on said motor, or broken or jamed pump impeller. You will need to remove the lower spray arm and filter assembly to get access to the pump impeller to see if it is jammed or broken. If you can turn the motor shaft but the motor just hums then the motor of motor start capacitor is gone. You can order the motor with start capacitor and impeller for around $130. Check for 120v at the motor terminals prior to replacing motor/pump assembly to confirm, 120v at motor would but motor not turning equals bad motor and or capacitor.
Posted on Feb 23, 2009
When starting the wash cycle, after 1-2 is shows HF.
do you mean f/h ,no water to unit ,,,check to make sure hot and cold taps are on both...check for kinked fill hoses ,,if theres water in unit already check,pump..it will not fill with water in unit,,make sure theres no leaks from hose anywhere,,,good luck, repost if moe help is needed
Sep 11, 2011 | Kenmore HE3T Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water won drain. stuckin last wash cycle and it
sounds like your pump is jammed,or faulty.remove water from unit by hand pull away from wall about 2ft tip unit back so u can look underneath. to the right hand front of the unit u will see a red or black fan on the pump, turn that fan clockwise and anticlockwise to unjam pump if it is jammed.fan should turn easily.please turn off power b4 u work on it, dont want any accidents. when u have done this put unit back level, turn power on select spin and start. please reply 4 more help
Mar 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Kenmore HE2 front loader. The discharge pump
This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
4. Plug the unit back into the appropriate socket. If you continue to experience abnormal actions with the pump, replace the (CCU)
Oct 02, 2009 | Kenmore Washing Machines
While i'm washing water is getting on my floor, I don't know if it is when spinning or washing what could be the problem?
Help me help you...Dry the floor...Set the load size to small. Let it fill and start the wash cycle. Stop the unit. Look underneath it. Is there water on the floor? If so let me know. If not, start it up again and let it complete the wash cycle. As it begins to drain, look for water on the floor. Let me know.
I am trying to help you eliminate (or isolate) a bad tub seal, centrifigual force out, or a drain pump issue. When the water actually begins to leak is the key element we need to know in order to solve your problem. :) 2CR
Jul 31, 2009 | GE WJSR4160DWW Top Load Washer
Washer will not discharge water after wash or rinse cycle
Pump failure. Unit probably has something stuck in pump....the washer eats the socks not the dryer. suggest shope vac to get water out, and then remove hose from pump and check to see if its clear.
Jun 08, 2009 | Kenmore Washing Machines
Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
May 03, 2009 | Dishwashers
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
420 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
