Question about Philco 841.169 Turntable
I have Philco 841.169 model and when I press the phono button so I can play an LP, it keeps showing the word "LINE" what does this mean and how I can start my turntable?
  • 104 Answers
About 3% of the time the 'brains' get scrambled, try unplugging it from the wall for a few minutes, sometimes this will 'fix' it.
if so, a power surge from your power company might have got it confused, if the problem continues try a surge protector power strip.
Posted on Feb 11, 2009
I have a Yamaha RV-V450 receiver. Where can I hook up my turntable. I have tried many different options. I can hear very faintly the record playing but only after turning the volume up. I am having trouble...
Turntables generally do not have a strong enough signal to drive an amplifier. You can check on the back of your turntable and see if it has a switch to change from phono to line level. Most do not, but a few will.
If your turntable does not have this switch, you will need to purchase a phono amplifier to boost the signal to standard line level. You can get these on ebay for around $15.
You connect the turntable to the phono amp input and then connect the phono amp output to any of the inputs on the back of your receiver (aux, cd, etc).
NEW BOZAK Phono Preamp Pre Amp Record Player Vinyl LP Album Amplifier eBay
Dec 30, 2017 | Yamaha Audio Players & Recorders
What does the photo button mean on my Pioneer receiver SX 205
You surely mean the phono button.
It's a preamp which adds 32 dB of gain. But first make sure you don't blow up your speakers by turning the volume down.
Different companies have different settings.
To enable the phono preamp in some systems, Press and Hold the Phono button for a few seconds.
Jun 21, 2015 | Pioneer Audio Players & Recorders
How to burn a Cd
The Sony MHC-BX2 can record from a CD to a cassette tape. This model doesn't have a CD burner. The manual for the MHC-BX2 is available from Sony support: http://esupport.sony.com/US/p/model-home.pl?mdl=MHCBX2&template_id=1&region_id=1&tab=manuals#/manualsTab . See page 12 of the PDF.
If your unit is a different model, please post a comment with that model number. I wish that I had better news for you.
(on those shelf systems that can burn a CD, place a blank CD-R or CD-RW (if supported) in the disc tray. Use the function button to set the recording source (Phono with the Croseley units). Place the tape to record in the tape deck and press play reach a point a bit before the desired point to start the recording. (Some also will record from the radio, turntable, or other device. Again start the source playing.) Then press CD Record. Press Stop when you want the recording to stop or when one side of the tape/LP is finished. (Some have a Split Track button if you want to identify every track. Press this during the silent period between songs.) Otherwise, you will get one track per side with tapes/LPs.)
Jul 10, 2012 | Sony Audio Players & Recorders
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
My new behringer vmx 200 dj mixer dosnt play sound from ch1 ...ch2 works fine ive tried everything but ch1 dont work
be sure when you select the chennel 1 input as your audio source you have an audio device plug inn at the channel 1 audio input..
Sep 11, 2011 | Audio Players & Recorders
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
Feb 27, 2011 | Universal Electronics Ion LPDOCK USB...
How do I connect a disk player (LP)
That would depend on the turntable model andits capabilities. If it's old-school, non-preamplified, you would need an external phono pream first, then run it into the Aux or any other available Line Level input.
Some contemporary turntables have their own selectable internal preamps for use with modern receivers which do not have phono sections. They would jack into any Line Level input.
Feb 19, 2010 | Philips LX710 System
When I try to record vinyl records it gets no
Press STOP to stop recording.
Click "save" and save the recording to a file in your "My Documents" folder.
Open your "My Documents" folder.
What is the "size" of the file?
Click with the SECOND (usually the RIGHT) mouse-button on the file, and click 'Play' (with Windows Media Player).
Does it play?
Does Windows Media Player show the correct length (minutes:seconds) for the recording?
Nov 09, 2009 | Sony Sound Forge Audio Studio 9 Full...
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
what do you mean it drags? I noticed if you don't pull the arm back far enough,it will turn on,but the arm will drag foward scratching your record. Try pulling it bacl ALL the way and then it should give you no problems.
Sep 29, 2009 | Philco (R) Classic Turntable CD Shelf...
Standby button fails to go green
if there is a remote control does it work from it?
have you tried removing power from the wall for a few minutes then retry, sometimes the computer inside gets scrambled brains and a hard power reset might wake it up.
Feb 09, 2009 | Philco 841.169 Turntable
Philco 841.169 Turntable Logo
109 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Morne Olivier
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
