Question about HP Photosmart 2610 All-In-One InkJet Printer
Won't take paper, says it is out of paper when paper is loaded
Last time it took paper, it took more than 1 page. Since then it says it is out of paper, add paper and press OK. I do this and it won't **** in the paper - this is 8.5 x 11 20 lbs copy paper.
    Guru:
  • 1,463 Answers
HI THEKERBS
have a look here at there site this may help you solve it HP Photosmart 2610 All-in-One Printer
riz.
Posted on Dec 20, 2008
I have a Samsung scx 4623fw printner. When I print one page, the machine will send 2nd page following first page causing page 1 jam at exit 2 and p2 jam on exit 1. It happens every time. Can someone h
On the document that you are trying to print, go to the very last word, of the last page.. hold the shift key down & use your down arrow to highlight anything below, no matter how long it may be highlighting white space. Hit your back arrow once. Check the last word for punctuation & spelling, resale your document & try to print again.
A lot of times in the course of 'composing', extra carriage returns or tabs or spaces, are added to the bottom of the document. I have just explained how to clear the second page printing. It may also remove the erroneous codes that may have formed.
Rebooting a printer has the same good effect as rebooting your computing device. It clears up a lot of confusion that has stacked up since the last time you did it.
If you have printed labels with this same printer, you may have part of a label throwing off the paper path. Also make sure that the paper guides in your paper bin or manual feed area are close, but not touching or pinching the paper. This can cause paper to go off of its normal print path.
Good luck.
Toby.
Aug 31, 2015 | Office Equipment & Supplies
What can I do to stop my hp deskjet 2540 from cutting off bottom of page
Obviously this is whilst printing, as opposed to copying.
Check the page size versus the paper loaded. If the page size is longer (e.g. A4) and the paper size is 8-1/2 by 11 (wider than A4 but shorter) you'll lose the last few lines.
Jan 23, 2015 | HP Office Equipment & Supplies
My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
Thank you for contacting FixYa with your printer inquiry.
This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
Hope this helps helps. Please keep us updated and remember to rate this answer.
Sep 02, 2010 | HP LaserJet P3005 Printer
Paper keeps shifting during loading and eventually gets jammed every time
Seems like the rollers are either dirty, or worn out. Probably the latter.
“Paper jams” on page 68
“Paper or specialty media misfeeds” on page 68
“Printer does not feed paper, envelopes, or specialty media” on page 69
“Banner paper jams” on page 69
Paper jams
Is the jam in the paper
support?
1 Press to turn off the printer.
2 Firmly grasp the paper, and gently pull it out.
3 Press to turn the printer back on.
Is the jam in the printer? To automatically eject the paper:
2 Press again to turn the printer back on.
The paper automatically ejects from the printer.
To manually remove the paper:
If paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together, try the following solutions.
Check paper
condition
Use only new, unwrinkled paper.
Check paper loading Load a smaller amount of paper into the printer.
Load paper with the print side facing you. (If you are not sure which side is the printable
side, see the instructions that came with the paper.)
See “Loading various paper types” on page 21 for information about:
Maximum loading amounts per paper type
Specific loading instructions for supported paper and specialty media
Troubleshooting
68
Remove each page as
it is printed
Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper
guides
Adjust the paper guides:
When using media less than 8.5 inches wide
To rest against the edges of the paper or media, making sure it does not buckle
Jul 22, 2010 | Lexmark X2500 All-In-One Printer
Document feed takes more than one page at a time
please follow these steps to solve your problem:
1.Fan the papers before loading them in printer tray.
2. Dont use papers that has lot of wrinkles
3. Dont insert your papers too long into your printer. Just load them with optimal distance.
4. After the papers were loaded, adjust the paper hold knob present on either side of the paper such that it holds the paper firmly on both sides.
Now your printer will take one paper at a time for printing.
I hope this is helpful to you. Please provide your rating and comments for the solution provided.
thanks
Mar 08, 2010 | Office Equipment & Supplies
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Load 8 1/2 x 11 r
Make sure the paper is set up to the correct size in the paper handeling setup and on the PC you are printing from.
Oct 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
Jam bothed ways
try this link and scroll down the page and see if anything on the page helps you out... HP LaserJet 6L Printer paper jam both ways Google Search
Oct 24, 2017 | HP LaserJet 6L Printer
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
Not noticing paper
I took an envelope, folded in the end to triple its thickness and placed it in the middle of the paper tray underneath the very last page. This pushed the center of the paper up more and it had no problem detecting or getting hold of the paper. Have to be sure the paper supply tray is full though. When it gets to the last five or seven pages it has difficulty again. It's a nontechnical fix, but it seems to work.
Dec 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
