Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Homelite backpacker blower # uto08083 not running
I dropped it and the plastic covers over the carb adjustment screws broke off screws still intact tho, i tried to adjust carb after it started running rough now it wont run at all...  it then  ran until it got hot   and now it wont start      thank you
  • 47 Answers
Fist thing is run both the carb screws all the way in then back them off 1 1/4 turn this will be your starting point then start the blower to fine tune the carb if it starts then your carb was off giving it to much or to less fuel
Posted on Feb 05, 2009
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
I have a Homelite UT08580 26cc MightyLite Backpack Blower. Since new it has run poorly if at all when the choke is in the run position. Normally I have to use it when in the 1/2 choke position. It has caps...
If you have'nt yet you should put a kit in the carborater,if that does'nt fix it{should} then you may have a plugged muffler,.if you can't get rid of exhaust you can't be reved up.
Dec 09, 2009 | Homelite Consumer Products Backpack...
How do I identify the exhaust outlet on my homelite backpacker - I believe i need to clean it
look for black /burnt looking/smelling of oil there will be some form of guard covering it , usually 2 screws holding it on ( allen or torx ) , when removed take it outside and carefully pour petrol into it and very carefully set it alight to burn out any carbon /oil deposits
Nov 16, 2009 | Homelite Consumer Products Backpack...
Blower will not achieve maximum rpms and bogs down when accelerated
most new homelites etc have the high speed screw too lean because of epa standards---you usually need a special tool either a splined or pac man screwdriver to open the adjustment screw another 1/4 to 1/2 turn to get the right rpm's
Nov 07, 2009 | Homelite Consumer Products Backpack...
Its running too lean..there is a plastic cover over the carb adjustment screws
That may be to keep dirt out. One of the screws should be for the richness setting and the other for the idle speed.
Adjust the richness setting so the tool runs the best (fast) then turn the idle speed down to normal.
Make sure you always keep the air filter cleaned or dirt will get into the carb and cause you to have to clean out the jets in the carb.
Getting the right tool to adjust carb on Homelite Blower.
Type in "AYP" on google...scroll down to "jackssmallengines.com, in the AYP part number box type number 530035560.
May 06, 2009 | Homelite Consumer Products Backpack...
Carb adjustment tool
It is probably a star or a square head. You should be able to pick up at any auto parts store.
Hope this helps
Kurt
Mar 18, 2009 | Homelite Consumer Products Backpack...
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
758 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Homelite Garden Expert? Answer questions, earn points and help others
