Question about HP NC8000 (DE503AV) DVD+RW Burner
Looking at a used NC 8000-any known issues
Also how old is this unit!
  • 235 Answers
The good: First-class performance; excellent battery life and keyboard; runs cool; has firmware security. Looking at a used NC 8000-any known issues - b.gifThe bad: Old 2003 A tad bulky; stiff pointer controls.
b.gifThe bottom line: The fast, sturdy, and highly secure nc8000-series notebooks make excellent enterprise machines.
Specifications: Processor: Intel Pentium M (1.6 GHz) ; RAM installed: 512 MB DDR SDRAM ; Weight: 6.6 lbs
If you paying anything over 150 bucks for it go for a new one some can be had for 400 bucks .Bestbuy had a labtop for 99 bucks if you sign up with att for 60 a month for internet .
Posted on Dec 21, 2008
Need copy/compaq nc 8000
Not sure what you mean. Need you to clarify.
Are you needing the Restoration Disk?
Post back in a Comment.
Regards,
joecoolvette
Mar 04, 2013 | Computers & Internet
Rats got into the heating coil and ate away the insulation. How and where do I get that fixed? It's a Northstar 3,500 OSI hot unit. My zip code is 28226 in Charlotte, NC.
Any of the companies listed below can help you and are located in your area. These are all trained and certified service centers that specialize in pressure washer repair among other things.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
INNOVATIVE CLEANING SYSTEMS (ICS)
8724 WEST MALBORO ROAD
FARMVILLE, NC 27828 UNITED STATES
(252) 521-4291
CTS CLEANING SYSTEMS,INC
2185 ANGELIA M. STREET
FAYETTEVILLE, NC 28312-8398 UNITED STATES
(910) 483-5349
CSC INDUSTRIAL SALES & SERVICE LLC
600 - D UNION WEST BLVD
MATTHEWS, NC 28104 UNITED STATES
(704) 684-0223
MVP SERVICES, INC.
5813 A. TRIANGLE DRIVE
RALEIGH, NC 27617 UNITED STATES
(919) 788-0267
CLEANING SYSTEMS OF THE TRIAD
5610 RANDLEMAN RD.
RANDLEMAN, NC 27317 UNITED STATES
(336) 676-7283
Mar 11, 2011 | Northstar Garden
How do i set the timing on it?
Tork 8000 series cycle timer has built in trippers located around edge of dial.
Lift up the trippers to set on-off operations.
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
http://waterheatertimer.org/images/Tork-8000-600.jpg
The trippers are either up or down.
Tripper up = NO terminal on, NC terminal off
Tripper down = NO terminal off, NC terminal on
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | TORK Variable Cycling Timer 8601
Does the 8000 BTU unit need 15 or 20 amp wiring?
Find the nameplate ratings if they are still readable for this unit to see what they recommend.
Ideally a seperate circuit for this unit.
#14 minimum wire for 15amp
#12 minimum wire for 20 amp
May 16, 2010 | Frigidaire FAA068P7A Air Conditioner
M-series gateway (m1629) press start button, nothing
Taken apart, looking for abnormal solder etc checked powers switches decided that this unit was acting like it may have shut down due to excessive heat issue. pulled battery on board, tested ok, re-installed everything and found that this unit now is active. Conclusion: I suspect the bios shut this unit down, hard reset correct this issue.
Aug 24, 2009 | Gateway Computers & Internet
Need lg crn 8241b driver, missing
Hi, did you re-install or is the drive just "missing" without other problems?
If you re-installed, we can provide a link to a driver, if it just went missing, the driver is not the problem and there is a fix for a known issue where dvd's disappear you should try. I will post the link to the fix below.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 11, 2009 | LG CRN 8241B (CRN-8241B) Internal 24x...
Window unit air conditioner leaking water inside home
well it might not be tipped at a angle so the water comes to the front tip it back some
Jul 10, 2007 | Fedders X Chassis A6X08F2A Air Conditioner
Open Questions:
24X7 Free availability and assistance for toshiba support. Are you witnessing issues in your Toshiba laptop like your laptop isn't working since you installed an app, driver or update? Many Toshiba laptop and pc users report issues they face in their day to day life. Toshiba technical support is always available to help customers confront such situations and resolve issues for better working laptops and their longer productive lives. In case your Toshiba laptop is not letting you peacefully open the start menu or you are facing troubles installing any update or your newly installed update is not working the way it was supposed to then this article will help you in getting all the right answers for your issues. Toshiba support email is always available to help its customers at any time of the day and they even provide on-site support facilities. Toshiba support is provided by experienced and professional technicians who use industry authorized advanced technical tools and techniques to cater fully effective measures used to counter all possible issues that interrupt the productive working of Toshiba devices. In case you are facing issues in your Toshiba laptop you simply call our Toshiba laptop support , you can find out the cause of those issues by restarting your pc in the safe mode. Taking this option will remove all those apps, drivers and updates you have installed after the restore point was created but nothing will happen to your personal files. For using the restore point, you have to go to the control panel and type recovery in the search bar of control panel window. After that you have to choose the option of open system restore and click on next. You have to then select the most recent apps, drivers and update and click on the option of scan for affected programs. You can always contact Toshiba customer support using their toll-free helpline number +1888784-9316. They will provide on-site and on-line support assistance over the phone, email or chat. If restoring from the restore point doesn't help then you can reset your pc and wait for issues to get resolved. Resetting results in reinstalling of Windows after choosing which files you want to keep or remove. Resetting option is available in the settings menu. Under the sub section of update and security, there will be the option of recovery which will further have an option of reset this pc. For assistance in technical issues you can contact Toshiba customer care anytime.
Sep 24, 2018 | Toshiba Computers & Internet
See all HP NC8000 (DE503AV) DVD+RW Burner Questions
Computers & Internet Logo
245 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
