Question about NetGear WGR614 Wireless Router
I have got a new NETGEAR Router . i want to install it, but i am clueless how to start
  • 854 Answers
Here are some troubleshooting steps that I suggest you try: 1. Check physical connections. a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up. b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up. 2. Access the router's web-based utility. a. Please open any web browser like Internet Explorer or Netscape Navigator. b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password". Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default. To reset the router:a. Please push the reset button at the back of the router and release after 30 seconds. b. Unplug the power adapter for 10 seconds and then plug it back in.3. Configure the router. If your Internet Service Provider is using a cable connection, please follow the steps below: a. Click on Basic Settings under Setup tab. b. Select No for Does Your Internet Connection Require A Login?. c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button. If your Internet Service Provider is using a DSL connection, please follow the steps below: a. Click on Basic Settings.b. Select Yes for Does Your Internet Connection Require A Login?.c. Select Other on the Internet Service Provider drop down box.d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.4. Configure the wireless settings. a. Click on the Wireless Settings under Setup. b. Change the SSID to any unique name. c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy). d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit". e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number. Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection. f. Click Apply button to save the changes. g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.5. Power cycle. a. Power off the modem, router and computers. b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking. c. Power back the router and the computers. Check if it will be able to get online. If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below: 6. Connect wireless computer to the router. If you are using Windows XP with Service Pack 1, please follow the steps below:a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Advanced tab. d. Please delete all the preferred networks then click on OK. e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key. f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router. g. Make sure not to enable IEEE and then click on Connect.If you are using Windows XP with Service Pack 2, please follow the steps below:a. Please right click on the Wireless icon on the right lower end portion of your computer. b. Then click on View Available Wireless Networks. c. Click on the Change Advanced Settings. d. Click on the Wireless Networks tab remove all the preferred networks then click on OK. e. Right click on the Wireless icon then click on View Available Wireless Networks. f. Select your network and click on Connect. g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router. If you are using Windows Vista, please follow the steps below:a. Click Start then select Connect To. b. Connect to a network window will show up. c. Select your wireless network and click Connect. d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect. From the above configuration, please check if you can now access the Internet.
Posted on Jun 08, 2009
NetGear Wireless Router and NewGear WG111 Adapter
I imagine you bought the WG111 Kit. It could but throught the Router and/or the adapter. Uninstall all netgear software and drivers. Unplug the adapter. Reboot machine. Plug the adapter in and install the software drives. Basically your starting over. This will take the quess work out of trying to repair what was lost. After reinstalling go to this web page to configure the SSID,IP and adapter. http://kbserver.netgear.com/kb_web_files/N101179.asp
Jun 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I recently converted from cable DSL to AT&T. My netgear wireless router worked perfectly. I installed the 2WIRE and have not been able to get a connection to the internet. The DSL light is on but...
Are you trying to install the router.
You can do it manually without the CD.
make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 15, 2010 | 2wire 2700HG-B Router (2700HGB)
Netgear Super-G Wireless Router WGT624 v4
This really happen when you run the setup CD of a router sometimes it will tell you that there's no internet connection on your network but the truth there is so if you still need further help for this since the router is new better call Netgear and let them hel you all the way in configuring this router this is the complete list of phone number for Netgear tech support just check the linkfor it
http://kbserver.netgear.com/kb_web_files/N101460.asp
Hope that helps.........
Aug 10, 2008 | NetGear WGT624 Wireless Router
Netgear wgr614 keeps loosing signal
give the dns value in your wireless connection. and after then you see the proxy server is there or not if there then remove it if not there then check it.
Jun 12, 2008 | NetGear WGR614 Wireless Router
New computer lost install disk!
Hello, Here is a link for the firmware and drivers for your router. Hope this helps.
http://kbserver.netgear.com/products/wgr614v6.asp
Mar 23, 2008 | NetGear WGR614 Router
Adding computer to wireless router
1st reset the router and it will go to factory defaults.
button on the back.
no passwords..etc.
is this the only router you have connected to the modem?
if not then set this router for no dhcp.
Jan 26, 2008 | NetGear WGT624 Wireless Router
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
NetGear WGR614 Wireless Router Logo
54 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
