Question about HP Compaq 1501 15" LCD Monitor
MONITOR GOES TO SLEEP WHEN TURNED ON BUT PC IS NOT IN SLEEP MODE
Posted by cucumo on Dec 20, 2008 Actually, when I turn my monitor on a "Going to Sleep" message is displayed on a black screen and then the screen goes all black. We had a power outage acouple of nights ago and the pc was on. Since then our power has shut off and right back on about 4 or 5 times and of course the pc was on every time. It is a Compaq 1501 flat screen monitor and I am using Windows XP operating system. Any one out there have any ideas how to fix this problem?
2 Suggested Answers
  • 3 Answers
SOURCE: When I turn my monitor
It will be video cable or related.
Responding to prior post,
Fuses have nothing to do with the video proper.
If you have a message on the screen, which says the monitor is basically working or saying the fuses and inverter is working.
That message appears with lack of video, so it can be the cable itself, possibly the video card on the computer.
Posted on Apr 26, 2009
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Yesterday I was on the computer and the screen just went jagged with colors, best way to describe that. I pulled the plug since was was getting no response from ctrl alt+ delete. Or my big brother keyboard...
you might pressed a key on the monitor repress it and enable the monitor or else just remove ram from the cpu and clean it and replug it might it solve your problem
the last solution is to just format your pc
Jun 03, 2017 | HP Pavilion s3000e (GC387AV) PC Desktop
HP w1907 LCD Monitor goes to sleep by displaying a "monitor is going to sleep"error after turning on the computer and doesnt display anything. It works intermittently, in that, if the computer has been...
so if you test the monitor on a known good PC it does what?
fails, then its the monitor
works then its the failing PC
all old HP monitors pre 2010 many had a sleep timer
so push the menu key on the monitor
then look for sleep timer and turn it off,
the monitor defaults to that mode, so dont push reset monitor or bam back to sleep mode it goes. so turn it off again.
all this is in the manual, lost yours, wana read it first?
read page 4.7 see that? (osd +advanced +) power saver OFF
https://www.manualslib.com/manual/418165/Hp-W1907-19-Lcd-Monitor.html?page=25#manual
if that fails to fix it (tested on 2 PC ) the PC1 is bad.
that be a whole other WALL OF TEXt, ask.
Dec 10, 2017 | HP w1907 LCD Monitor
F1905e Monitor: When I turn on the monitor it goes straight into s...
The screen turn black may not mean it gos into sleep mode, it may mean it goes into shutdown mode because it may be sensing problem in the circuits.
Try it on another PC first, if it still does not work then read below.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | HP f1905e Monitor
After pc gets turned on it goes into sleep mode with no response.. need troubleshooting help.
Hello ahmid7 …
There are three potential areas for your solution (listed in descending order of probability).
1. Power Options
Are you familiar with Windows' "Power Options" control panel module? If in fact your system is going into sleep/stand-by/hibernate mode, this will be the most probable culprit, and you won't need to proceed to steps 2,3. With it you can tweak all things related to power saving (e.g., sleep, stand-by, hibernate, timed automatic MONITOR and/or hard-drive shut off, etc.). Just make your desired (re)adjustments there.
[Control Panel > Power Options]
... OR ...
Start > Run > type "powercfg.cpl" (without quotes), then hit Enter.
Once it launches, you'll probably find most everything self-explanatory. If not:
  • Search for "Power Options" in your Windows "Help and Support". Then review "…Common Tasks…" and/or "…Overview…" related items.
  • Post here again and I'll be glad to walk you thru it.
2. Monitor's OSD (On Screen Display / Setup)
If step 1 is unsuccessful, it may only be the monitor (CRT/screen/display) itself that is turning off. Somewhere on the monitor there will be an OSD (On Screen Display / Setup) button/switch of some type. There you may be able to make the needed adjustment. If necessary, refer to the monitor's documentation (i.e., User's Manual, etc.) for further details.
3. System BIOS
If steps 1+2 are unsuccessful, it may be your computer system's BIOS accommodates auto/timed shutoff of your monitor, hard-drive(s), motherboard. If necessary, refer to your computer system/BIOS documentation (i.e., User's Manual, etc.) for further details on how to adjust.
IMPORTANT NOTE:
If none of the above provides solution, please report this, because it may be that your system is NOT in fact going into what you perceive as a sleep type mode, but rather is experiencing an emergency shutdown. In this case there are a couple of most likely causes. However, there's no need to cross that bridge unless it actually exists.
Good luck, and thanks in advance for posting back ...
  • to provide clarification or feedback.
  • if you have any further questions.
  • to let me know how things worked out.
"Today's the best day of my life...and NOW you're part of it!" … Craig
Sep 19, 2009 | X2Gen MV20TP Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
HP Compaq 1501 15" LCD Monitor Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
